Results 1 to 6 of 6
Thread: mc2 audi 200 engine swap issue.
  1. Member skateboards and mk2s's Avatar
    May 16th, 2006
    CO
    85 audi coupe, 85 audi 4000, 85 GTi, 87 scirroco, 87 golf GT, 96 GTi, now 85 Golf.
    10-04-2012 06:50 PM #1
    Anyone ever had an issue with the starter motor continuing to crank after the ignition switch is off?
    Here is the deal.
    Start the car runs fine.
    Turn off the car starter continues to crank.
    disconnect the battery and the starter stops.
    Reconnect the battery and it is fine until you cycle the key again.
    We took out the ignition switch and jumped the wiring. same issue.
    New starter solenoid in. Same issue.
    Any ideas?
  2. Junior Member
    Jan 25th, 2011
    Colorado
    10-04-2012 07:53 PM #2
    The only time I've had that issue was with a bad starter. I went through a couple. The first one was turning the engine over slower and slower until one day it would just click. The next one did what yours is doing, it would start the car great, but occasionally it would get stuck cranking even if I would pull the key completely out. This one was actually from an MC1 that had been siting in the junkyard for awhile, so not a huge surprise I guess. A brand new starter and the car has started great ever since.
    So I would try a whole new starter, I'm sure that'll fix it. I would have thought a new solenoid would make it work, but there must be something else that gets stuck in there.
    -Rog
  3. Member skateboards and mk2s's Avatar
    May 16th, 2006
    CO
    10-05-2012 10:20 AM #3
    Thanks for the reply. We changed to a known good starter and still the same issue. I went through and reran every wire, cleaned all connections and checked far any issues. Didnt find anything really wrong but afterwards it has not done it again yet. Heres to crossed fingers.
  4. Member Jazzydub's Avatar
    Oct 13th, 2009
    Snohomish WA
    JB 20th 0440, 1987 Audi 4kq, 1998 Yukon, 1969 Datsun 2000
    10-09-2012 11:38 AM #4
    We jumped a wire off the starter solenoid once and it did that. I don't recall what wire it was.
  5. Junior Member 4rgsncps's Avatar
    Oct 1st, 2012
    Maryland
    1985 Audi 4000q, 1991 Jetta Coupe, 1990 Jetta Coupe
    11-10-2012 08:19 AM #5
    I have a '85q and have been contemplating a 200 swap. Any advice? Should I get the whole donor car or in pcs. I Alsohad this happen with my Jetta even after a new starter. Changed to a new relay and fuse it stopped!
  6. Member skateboards and mk2s's Avatar
    May 16th, 2006
    CO
    11-10-2012 11:18 AM #6
    The main advice I can give is to go slow. Torque everything correct, clean every ground before reinstalling and label every single wire and vacuum line clearly upon removal. Having the complete car parked right next to yours is huge but not totally necessary. Factor your total budget then add a third more.
