VWVortex.com - Coolant question?
    Results 1 to 7 of 7
    Thread: Coolant question?
    1. Member Scirocco16's Avatar
      Feb 3rd, 2012
      Kansas
      '87 Scirocco 16V
      10-04-2012 08:05 PM #1
      I just got some blue g11 coolant planning to flush and replace it. Now I'm wondering if I should have gotten the pink g12 instead? The car has green coolant in it now, will the residue react with the new g11 at all? Do I need to take special precautions when flushing it? They say its not good to mix g11 and g12.
    2. Senior Member Chris16vRocco's Avatar
      Apr 29th, 2006
      Maryland
      Scirocco x2, QSW, FJ40, E30, S4, W123, 745GLE TD
      10-04-2012 08:07 PM #2
      Make sure you flush it thoroughly and you'll be fine.
      Nil Satis Nisi Optimum
    3. Member Scirocco16's Avatar
      Feb 3rd, 2012
      Kansas
      '87 Scirocco 16V
      10-05-2012 10:15 AM #3
      ok, thanks! is the flush procedure in the bentley?
    4. Member Scirocco16's Avatar
      Feb 3rd, 2012
      Kansas
      '87 Scirocco 16V
      10-07-2012 06:47 PM #4
      Why is there no DIY for flushing the coolant on a 16v? I guess it's just common knowledge? I've heard about the "air in the system overheating" problems, and seen a few short replies about how to burp it out, but I'd really like some complete instructions about how to get things completely flushed out and properly filled so there's no issues. Call me a noob, but I'm 17, and I haven't had a huge amount of experience, but I can usually figure things out ok with a decent explanation.
    5. Member rabbitnothopper's Avatar
      Oct 19th, 2009
      D-Town REPRESENT : Texas
      RIP81. 78 VW Rabbit 1.5L EH 4speed 020 GC->GP, 82 Rabbit Pickup 1.6D
      10-08-2012 01:07 AM #5
      flush a coolant system:
      two options
      #2, pressure flush using a high pressure system while the engine is running
      shops tend to do this
      however it can inadvertently blow your headgasket if used improperly.
      #1 driveway flush
      USING DISTILLED WATER (.89cents/gallon)
      drain and collect the old coolant
      refill with distilled water
      run engine Open the Heater valve on the AC
      run engine until radiator fan kicks on twice
      shut off engine and allow to cool (30-60 minutes)
      drain water/coolant mix
      using Pensoil Radiator Flush (small yellow bottle)
      pour in flush treatment, fill with distilled water
      Run engine until warm again
      allow to cool
      drain flush treatment
      refill with Distilled Water
      run engine until warm
      shut off and drain
      refill with Distilled water but dont run it this time
      drain it then refill with 50/50 mix of your Coolant
      DONE.
      DISTILLED WATER does not contain metal particles that Tap/Garden hose water contains
      these metal particles CAN and WILL rust out your coolant passages over time
    6. Member Scirocco16's Avatar
      Feb 3rd, 2012
      Kansas
      '87 Scirocco 16V
      10-08-2012 01:15 AM #6
      Hey thanks for the info! I got som lubro moly rad cleaner that should work in place of the Pennzoil rad flush. I'm gonna install a new overflow tank, level sensor, and heater valve; guess I should do that in between flushes sometime. Should I fill it through the tank and drain it through one of the lower hoses?
    7. Member Scirocco16's Avatar
      Feb 3rd, 2012
      Kansas
      '87 Scirocco 16V
      10-08-2012 09:29 PM #7
      do I have to remove the t-stat to drain the block???
