VWVortex.com - Exhaust cam gear Making Noise
    Results 1 to 6 of 6
    Thread: Exhaust cam gear Making Noise
    1. Member Shamrock's Avatar
      Aug 6th, 2004
      Harrisburg, PA
      10-04-2012 08:51 PM #1
      I have about 1000 miles on my new motor and for maybe the last 150 or so miles when I start it up it makes that noise.. then goes away once I start driving.. if I go into the store and come back out in an hour it doesn't show up. When I come back out from work after 8 hours it will start to make that sound again than go away... as you can see in the video it starts to go away after a few minutes.. the video is chopped so like 3-4 minutes it goes away. I'm wondering what the issue is. its just coming up on 1000 miles now so this weekend I'm going to drain the oil
    2. Member Shamrock's Avatar
      Aug 6th, 2004
      Harrisburg, PA
      10-05-2012 10:40 AM #2
    3. 10-05-2012 10:44 AM #3
      You sure your belt isn't too tight (presuming you're on the manual tensioner)?
    4. Member Shamrock's Avatar
      Aug 6th, 2004
      Harrisburg, PA
      10-06-2012 02:59 PM #4
      I am... I can turn it with my hand perpendicular.. should I try loosening it alittle more?
    5. Member TooLFan46n2's Avatar
      Oct 18th, 1999
      Lancaster PA
      '08 Jetta 2.5 '02 GTI 337 '97 BMW 328i
      10-07-2012 10:23 AM #5
      Mine does the same thing. IE tensioner, modified cat cam gear and stock belt. I'll have to check my tension as well. I believe went a tad tight rather than lose just to be safe.
      GTi 337.:R
      {PPT T3/T4 50 TRIM .63 Haldex Kit - Eurodyne Maestro - 630cc Injectors - IE Rods - AEB Head w/ VVT - CAT Cam Gear - Walbro Inline - Audi S3 Gearbox - Peloquin Diff - SouthBend STGIII Clutch - .:R32 LCA's/Spindles/Rack - Ksport Coilovers - Swaybars - Porsche BBK - Eurojet FMIC - FSI Coils - 2 Stage Boostvalve - HKS SSQV }
    6. Member Shamrock's Avatar
      Aug 6th, 2004
      Harrisburg, PA
      10-09-2012 05:09 PM #6
      I have stock cam gear and stock cam ARP bolt gates belt... obviously you can tell thatho..
