Results 1 to 12 of 12
Thread: part name????
  1. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    1998 vw jetta gls 2.0 ABA, 1992 vw cabriolet 1.8, and a 2002 kawasaki 636 zx6r ninja
    10-04-2012 09:14 PM #1
    can anyone tell me the real name and the part number for both right and left side of this
    if your ganna be dumb you gatta be tough lol
    tight is tight, to tight is broken
  2. Member sehaare's Avatar
    Aug 4th, 2003
    Palatine, IL. But I'll NEVER call Chicagoland home.
    2013 TDI Sportwagen, 81 Rabbit Convertible, 92 Cabby (Daughter's), 98 SUV, 2011 Legacy
    10-04-2012 11:18 PM #3
    Quote Originally Posted by CajunSpike View Post
    Which car is that from?
    It doesn't look like anything that I've seen on a cabby.
    "I'm a man, but I can change, if I have to, I guess." - Man's Prayer
    "Quando omni flunkus moritati"
    Handyman's corner
  3. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    10-05-2012 12:00 AM #4
    Quote Originally Posted by sehaare View Post
    I know its the part that holds the front wheel hub/bearings.
    The upper two holts bolt to the shock tower.
    the left hole bolts to the tie rod.
    The 'tangs' are where the brake calipers fit.
    Just can't tell if its from a cabby or cabrio/jetta.
  4. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    1986 Cabriolet Best Seller, 2000 Jetta VR6, 1990 Vanagon Westfalia
    10-05-2012 12:18 AM #5
    Good thing you posted ^that; led me to the proper place in the catalog.
    Name: Wheel bearing housing
    Part numbers (for mid-'84 to 1993):
    Left 171407255B
    Right 171407256B
    Cabby-Info.com -- Your online guide to the VW Cabriolets
    Old Blue's Blog -- The adventures of a 1990 Westfalia
    "Fashion is a waste of money that could be better spent on, say, maintaining your car." ~James May
  5. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    10-05-2012 12:37 AM #6
    you mean you guys couldnt tell it was a steering knuckle, aka spindle?
    it doesnt look like a mk1, probally a mk3 or other cabrio model...
  6. Member kamzcab86's Avatar
    Feb 13th, 2002
    Arizona
    10-05-2012 01:46 AM #7
    Quote Originally Posted by rabbitnothopper View Post
    I've never had to touch mine, so...
    Also, this is what the Mk3 version looks like:
    It's a tad different.
    The Mk1 version, FWIW, is now NLA.
  7. Member sehaare's Avatar
    Aug 4th, 2003
    10-05-2012 08:14 AM #8
    Nope, I had misjudged the size, I thought it was something that was about 5" tall. From Kams picture it was obvious.
    Handyman's corner
  8. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    10-05-2012 05:18 PM #9
    I knew what it was for...just couldn't think of the name to call it.........
  9. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-05-2012 08:07 PM #10
    its off a 92 cabriolet and i kno its also called the steering knuckle i just wanted the factory name lol
  10. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    10-06-2012 04:33 AM #11
    sorry, mk1 (1992 cabriolet) spindles look like this
    and are the same for all mk1
    these are also mine
    so your spindles if you got them from a 92 cabriolet, are not the stock spindles/steering knuckles.
  11. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-06-2012 08:18 PM #12
    the ones u posted is how mine look there just still on the car i found that pic on the net
