VWVortex.com - Winterized diesel
    Results 1 to 10 of 10
    Thread: Winterized diesel
    1. n00b
      Sep 30th, 2012
      Seattle
      2010 Sportwagen TDI/DSG
      10-05-2012 12:03 AM #1
      What kind of mileage reduction have folks been seeing from the "winterized" fuel? Mine has been about 5-7 mpg less. Just wondering if that's the norm for the 2.0 TDI. I just got my APR upgrade and was trying to establish a baseline when the winter stuff hit the pumps.
    2. Member aampsmb's Avatar
      Oct 3rd, 2007
      Roscoe, IL
      CW 2011 Golf TDI DSG 4-Door, 2007 Audi S8
      10-05-2012 08:01 AM #2
      Last winter I saw a reduction of 2-3 mpg vs. warm weather mpg. The temperature has more to do with your mpg dropping than the winterized diesel fuel. Common rail diesels are not designed to run on blended diesel fuels. DO NOT use any blended diesel fuel in your car. Your warranty will be voided if you torpedo the HPFP.
      Feb 21st, 2012
      Brighton, Michigan
      2016 Golf R 6M
      10-05-2012 10:04 AM #3
      I also see a 2-3 mpg reduction once the engine is warmed up. The biggest issue is the extended time it takes for your engine to warm up in the winter, especially if you take a lot of short trips.
    4. Member aampsmb's Avatar
      Oct 3rd, 2007
      Roscoe, IL
      10-05-2012 12:48 PM #4
      Quote Originally Posted by cd_booth View Post
    5. n00b
      Sep 30th, 2012
      Seattle
      10-05-2012 02:28 PM #5
      Quote Originally Posted by aampsmb View Post
      By "blended" do you mean the 5% biodiesel Shell sells? I haven't seen anything other than that. The gas stations should be required to post a placard on the pump if the fuel is blended, shouldn't they?
    6. Member aampsmb's Avatar
      Oct 3rd, 2007
      Roscoe, IL
      10-05-2012 03:06 PM #6
      Quote Originally Posted by JES2016 View Post
      Blended diesel is No. 2 diesel blended with No. 1 diesel (kerosene) or No. 2 diesel with an additive added by the manufacturer. Just stick with the Ultra-low sulphur diesel your local station sells and you'll be fine. Which is a 5% mix of bio-diesel.
      Some manufacturers used to mix gasoline for their winter diesel blends. Thankfully, here in the US we don't have to worry about that.
    7. Member chrisMk6TDi's Avatar
      Dec 10th, 2011
      Central MA.
      2015 Golf TDI, 2013.5 GLI AB (gone), 2011 Golf TDI (traded)
      10-05-2012 05:48 PM #7
      Isn't winterized diesel fuel ULS kerosene blended with ULSD? I cant remember why but I was under the impression that that was the standard mix in the northeast, at least?
      '15 Golf TDI SEL w/lighting package/Platinum Grey Metallic/DSG
    8. Member aampsmb's Avatar
      Oct 3rd, 2007
      Roscoe, IL
      10-06-2012 07:38 AM #8
      Quote Originally Posted by chrisMk6TDi View Post
      "Winterized" diesel in the U.S. is diesel blended with an additive by the manufacturer to prevent gelling.
      "Winter Blend" diesel is diesel mixed with kerosene. Semis can use this blend. Our CR diesels cannot.
    9. Member chrisMk6TDi's Avatar
      Dec 10th, 2011
      Central MA.
      10-06-2012 04:45 PM #9
      Gotcha. I'm used to hearing about the "blend" that the pumps at the DOT yard i work at get.
