Results 1 to 10 of 10
Thread: Winterized diesel
  1. n00b
    Sep 30th, 2012
    Seattle
    2010 Sportwagen TDI/DSG
    10-04-2012 11:03 PM #1
    What kind of mileage reduction have folks been seeing from the "winterized" fuel? Mine has been about 5-7 mpg less. Just wondering if that's the norm for the 2.0 TDI. I just got my APR upgrade and was trying to establish a baseline when the winter stuff hit the pumps.
    Oct 3rd, 2007
    Roscoe, IL
    CW 2011 Golf TDI DSG 4-Door, 1986 Porsche 944 Turbo: past vehicles B5.5 Passat W8 wagon: 1964 GTO
    10-05-2012 07:01 AM #2
    Last winter I saw a reduction of 2-3 mpg vs. warm weather mpg. The temperature has more to do with your mpg dropping than the winterized diesel fuel. Common rail diesels are not designed to run on blended diesel fuels. DO NOT use any blended diesel fuel in your car. Your warranty will be voided if you torpedo the HPFP.
    Feb 21st, 2012
    Ypsilanti, Michigan
    2010 Jetta TDI DSG
    10-05-2012 09:04 AM #3
    I also see a 2-3 mpg reduction once the engine is warmed up. The biggest issue is the extended time it takes for your engine to warm up in the winter, especially if you take a lot of short trips.
    Oct 3rd, 2007
    Roscoe, IL
    10-05-2012 11:48 AM #4
    Quote Originally Posted by cd_booth View Post
  5. n00b
    Sep 30th, 2012
    Seattle
    10-05-2012 01:28 PM #5
    Quote Originally Posted by aampsmb View Post
    By "blended" do you mean the 5% biodiesel Shell sells? I haven't seen anything other than that. The gas stations should be required to post a placard on the pump if the fuel is blended, shouldn't they?
    Oct 3rd, 2007
    Roscoe, IL
    10-05-2012 02:06 PM #6
    Quote Originally Posted by JES2016 View Post
    Blended diesel is No. 2 diesel blended with No. 1 diesel (kerosene) or No. 2 diesel with an additive added by the manufacturer. Just stick with the Ultra-low sulphur diesel your local station sells and you'll be fine. Which is a 5% mix of bio-diesel.
    Some manufacturers used to mix gasoline for their winter diesel blends. Thankfully, here in the US we don't have to worry about that.
  7. Member chrisMk6TDi's Avatar
    Dec 10th, 2011
    Central MA.
    2011 Golf TDI
    10-05-2012 04:48 PM #7
    Isn't winterized diesel fuel ULS kerosene blended with ULSD? I cant remember why but I was under the impression that that was the standard mix in the northeast, at least?
    '11 TDI Reflex Silver/DSG/AWE dual catback
    Oct 3rd, 2007
    Roscoe, IL
    10-06-2012 06:38 AM #8
    Quote Originally Posted by chrisMk6TDi View Post
    "Winterized" diesel in the U.S. is diesel blended with an additive by the manufacturer to prevent gelling.
    "Winter Blend" diesel is diesel mixed with kerosene. Semis can use this blend. Our CR diesels cannot.
  9. Member chrisMk6TDi's Avatar
    Dec 10th, 2011
    Central MA.
    2011 Golf TDI
    10-06-2012 03:45 PM #9
    Gotcha. I'm used to hearing about the "blend" that the pumps at the DOT yard i work at get.
