VWVortex.com - 020 Guru's please help
    Results 1 to 8 of 8
    Thread: 020 Guru's please help
    1. Member Sanityana's Avatar
      Mar 4th, 2012
      Charlotte NC area
      1988 16v Scirocco 80 Caddy 03 allroad
      10-04-2012 11:04 PM #1
      Hi I have an 88 16v Scirocco that came with an 020 FF transmission (which i like the gearing of very much) the previous owner had installed.
      Last week the "auto fail...er adjusting" clutch cable that came with the car failed. I bought a manual cable replace it with, but when I went to install it I noticed the clutch arm on the front of the transmission had almost no tension on it. After consulting some more experienced friends and a local shop everyone agreed the likely culprit was the small arm that presses in on the throw out bearing.
      Tonight I poped off the green cap expecting to find a bent or cracked arm and/or a mangled bearing to my surprise I discovered the push rod was barely peaking through:
      This raised a red flag but I decided to test fit the new bearing anyway
      With the new bearing in the arm that should be depressing it can barely make contact with it due to the push rod being so far recessed
      Any idea what caused this? How can I fix it? Is there any chance of me not having to pull the transmission to sort this out?
      All help appreciated!
      I've been trying to do right by this car (progress so far http://forums.vwvortex.com/showthrea...thread-88-16v) and correct all the previous owners wrongness, but funds are short right now and I'd really like to get this sorted out without having to fork over tons of loot to a shop.
      Thanks!
    2. Member Broke's Avatar
      Aug 13th, 2001
      Pickerington, Ohio
      86 GTI 2.0L, 88 Scirocco 16V, 2010 F150 STX
      10-05-2012 08:59 AM #2
      Quote Originally Posted by Sanityana View Post
      Did the pedal drop to the floor and stay as you depressed the pedal to use it or did the pedal just suddenly lose tension and was easy to operate?
      The release arm will be floppy and loose feeling, but you shouldn't be able to lift it above 9:00 by hand.
      It is very often that actuation finger that cracks, but it can also be the clutch parts. Generally you check the finger as it will cost you a green end cap and might save pulling the trans... if the finger is OK though then the box has to come out to inspect the clutch parts.
      Specifically, the thrust plate that is clipped to the pressure plate... if the pushrod punches a hole in the middle of it, you lose the ability to operate the clutch.
      The clutch is still grabbing fully, you just can't disengage it by depressing the pedal now, right?
      It looks like the pushrod has gone through the release plate, or some other clutch parts failure that is preventing the pushrod from being shoved back out by the pressure plate.
      It could be several things from just a worn out thrust plate to a bad pushrod bushing not supporting the end of the pushrod and allowing it to wobble and walk, accelerating the wear of the thrust plate center pad, an improperly adjusted cable can cause it, riding with your foot on the clutch can cause it, etc...
      No, it looks like the trans has to come out to inspect the clutch parts at this point.
      Slide the pushrod out (grab it with something and pull it out of the 5th end of the trans) and inspect the end for signs of it having punched through. If it is hard to slide out, it may be through the thrust plate, or if the end is bad it would indicate a problem at the clutch parts.
      Don't forget if you order a clutch that you have an 8V trans on the car, ordering clutch parts for the 16V Scirocco will get a clutch too large at the center hub for the FF trans input shaft, as that car should have an AGB or 2Y trans with the larger 24mm input shaft.
      020 trans info pages - www.BrokeVW.com
      NEW 0.7619 5th gears for the 020
      NEW 020 reverse gears
      '86 GTI 8V 2.0L -'88 Scirocco 16V - '10 F150 4x4
    3. Member Sanityana's Avatar
      Mar 4th, 2012
      Charlotte NC area
      10-05-2012 11:46 AM #3
      Quote Originally Posted by Broke View Post
      ----lost tension impossible to operate, but clutch cable way fraying and plastic parts looked worse for wear
      ----it topped out without any resistance
      ------Finger is actually in perfect shape, was really hoping it was the culprit
      ------clutch is not engaged and will not engage. If I put the car in gear and hit the starter it moves the car
      ----Yep, pretty much the conclusion I was coming too, but was hoping...
      ------The old self adjuster had the arm up pretty far, thinking clutch is/was at the end of its life anyway
      -----Yep making plans now with some friends next week
      ----slides in and out easily, both ends look normal
      ----Yeah I've though about going back to a 2Y (assuming one can be found) and just swapping out the 5th gear to have the close ratio 1-4. There kind of like hens teeth around here these days though and the car pulls hard even with the wider gears on the FF so I really don't have any huge complaints about it aside from the clutch problems of the moment. The higher top end is definitely fun
      Thanks for all the good feedback, I'm still in a transitional phase from air cooled knowledge to water. A lot is the same, but the transmissions are quite a bit different.
    4. Member Thrasher's Avatar
      Jul 18th, 2003
      Maricopa, AZ
      2011 CC 6-Speed (Daily Bomber), 1987 Scirocco 16v (Resto), 1993 Audi S4 (Monster in the Making)
      10-05-2012 01:00 PM #4
      Clutch release plate failed, guaranteed.
      You're welcome.
      This axe was made to grind.
      Bring me the soda bucket
    5. Member Sanityana's Avatar
      Mar 4th, 2012
      Charlotte NC area
      10-05-2012 09:03 PM #5
      Thanks much, hopefully I can get this sorted in the next couple weeks in time for some nice fall drives
    6. Junior Member Topper Harley's Avatar
      Sep 29th, 2012
      10' Impreza
      10-06-2012 10:01 PM #6
      Quote Originally Posted by Thrasher View Post
      You're welcome.
      I second this notion.
    7. Member Sanityana's Avatar
      Mar 4th, 2012
      Charlotte NC area
      10-08-2012 03:55 PM #7
      35 miles to friends shop, made it with just 2nd and 4th
    8. Member Sanityana's Avatar
      Mar 4th, 2012
      Charlotte NC area
      10-11-2012 10:27 PM #8
      2Y in, took the car out tonight. Very good upgrade!
