Thats correct, with a little time and adjustment you'll be able to get the driving position spot on.
An ideal driving postiton allows the pedals to be fully depressed whilst still keeping a slight bend in the leg.
Back must be straight against the backrest.
Arms must also be slightly bent.
If your going down the race seat route i assume you'll be using harnesses?
If so, make sure all the controlls can be reached once you've strapped yourself in. Harnesses are tight and hold you in place. You'll not be able to access the glovebox for example.
To make movement in car easier intertia reel harnesses are available, these will allow movement just like your regular belt.
https://www.europaspares.com/product..._700BLACK.html
If your using the car for racing the belt above may not be allowed under FIA rules. Fine for street tho
Alex.
