Results 1 to 8 of 8
Thread: B4 Gas Gauge Issues
  1. Member flatwhiteheap's Avatar
    Feb 14th, 2008
    Wekiva Springs, FL
    MK4 Jetta
    10-05-2012 07:52 AM #1
    When I start the car even on an almost empty tank the gas needle reads full, pretty much 99% of the time. Once in a while it seems on long drives, the gas gauge finally decides it's too tired from sitting at the full line, and it starts to drop slowly to where I think the gas should be be, although I have caught it creeping back up to the full line to while driving. When I get to my location, after the car has been sitting, and then start the car back up again it shoots right to full again.
    ........Not knowing how much gas you have is annoying!!
    "Ich bin ein Berliner"
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    10-07-2012 12:09 PM #2
    pull your sender and check it out.
  3. Member flatwhiteheap's Avatar
    Feb 14th, 2008
    Wekiva Springs, FL
    MK4 Jetta
    10-07-2012 04:49 PM #3
    Quote Originally Posted by antichristonwheels View Post
    You mean pull the pump itself and take a look?
  4. 10-08-2012 12:08 AM #4
    Your sending unit is in the pump under the rear seats. I'm pretty sure it is a separate piece from the pump but in the same assembly. I hope I'm giving the right info....
  5. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    10-08-2012 08:05 PM #5
    Quote Originally Posted by jaesiv View Post
    Sorta... it is not under the rear seats, but in/below the trunk, lift the carpet and there be a round cover held by three screws.
  6. Member flatwhiteheap's Avatar
    Feb 14th, 2008
    Wekiva Springs, FL
    MK4 Jetta
    10-08-2012 10:13 PM #6
    Well I know that the fuel pump is under the circle plate..I already looked at that, and nothing seemed out of the ordinary
  7. Member izzo's Avatar
    Mar 19th, 2004
    Manassas
    '89 Golf
    10-08-2012 11:05 PM #7
    I am not sure you mean "yes I pulled the fp assembly out to check on the fuel level sender".
  8. Member flatwhiteheap's Avatar
    Feb 14th, 2008
    Wekiva Springs, FL
    MK4 Jetta
    10-09-2012 07:30 AM #8
    Gotcha..I will do that this weekend
    Thanks for the help!!
