Results 1 to 11 of 11
Thread: Whats the outside diameter of the fuel filler tube that runs in the passenger rear wheel well
  1. 10-05-2012 11:59 AM #1
    Hoping its close to 1.75
    ALUMINUM ROLL BAR MOUNT WATER QUICK DISCONNECT
    *1 3/4" BAR MOUNT
    *AN-8 FITTINGS
    *PROGOLD AN-8 STAINLESS BRAIDED LINE - 90 SWIVEL X 45 - APPROX. 8" LONG
    *RACE USED
    *COMES FROM A LEADING NASCAR TEAM
    So I can rigidly mount this for my AWIC feed and return lines which exit the spare wheel well right near the Fuel Filler Tube... block of two of the ports.
    INLINE WATER CIRCULATOR
    *DUAL AN-12 INLETS & OUTLETS
    *2 THREADED BUNGS FOR QUICK CONNECT
    *RACE USED
  2. 10-05-2012 11:59 AM #2
    Quote Originally Posted by jettred3 View Post
    *1 3/4" BAR MOUNT
    *AN-8 FITTINGS
    *RACE USED
    *RACE USED
    Paid less than 60 bucks for both shipped....
  3. Member aeffertz's Avatar
    Dec 6th, 2009
    Ladysmith, WI
    '79 Rabbit, '84 Rabbit, 2012 GTI
    10-05-2012 01:09 PM #3
    Okay. Well I need that fuel filler neck. Where did you get that?!
  4. 10-05-2012 01:49 PM #4
    http://www.waterwagens.co.uk/mk1-golf-74-83-85-c.asp
    crappy ms paint drawing so you get the basic idea, we are trying to keep the lines that exit near passenger side rear wheel from fouling any moving items in the wheel well.....to the hardlines under the rocker / pinch weld.
    http://www.waterwagens.co.uk/vw-golf...back-614-p.asp
    AND
    http://www.waterwagens.co.uk/vw-golf...panel-24-p.asp
  5. 10-05-2012 01:56 PM #5
    as far as that fuel filler neck.....
    Sorry, this item is out of stock. Estimated delivery is 4-5 working days. Please contact us if you wish to be notified when stock arrives...
  6. 10-05-2012 04:33 PM #8
    Will be home in an hour, I guess I will know then..if this scheme may work.
  7. Member aeffertz's Avatar
    Dec 6th, 2009
    Ladysmith, WI
    10-05-2012 05:03 PM #9
    It's around that. I just measured my cap.
  8. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    10-06-2012 02:35 AM #10
    41mm guys
    1 5/8 inch
    did you research about the fuel tank issues?
    its either 7inches long or 16 inches long
  9. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    10-06-2012 02:37 AM #11
    Quote Originally Posted by aeffertz View Post
    is that the factory cap? i dunno never owned one
    you are totally missing the gasket which seals the filler neck
    thats bad
    they look exactly like 80's BMW and exactly like a stock metal OEL cap. (oil cap)
    so basically they just moulded a plastic fitting around a flat oil cap
