VWVortex.com - KESSY retrofitting
    Results 1 to 9 of 9
    Thread: KESSY retrofitting
    1. Semi-n00b
      Sep 26th, 2012
      St.Petersburg, Russia
      GTI'11
      10-05-2012 03:09 PM #1
      Hello everybody!
      I'm that crazy man who have nothing to do but KESSY retrofitting on my GTI VI
      I did wiring and had bought all components.
      I tried twice to adopt components on my local vw dealer (with on-line connect) but failed.
      An error occurs and nobody has idea how to deal with it
      Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
      Part No SW: 5K0 959 434 B HW: 5K0 959 434 A
      Component: VWKESSYPQ35GP 085 0902
      Revision: 00085000 Serial number: 0138253623
      Coding: 030C0C
      Shop #: WSC 00135 935 10496
      ASAM Dataset: EV_KESSYPQ35G A02014
      ROD: EV_KESSYPQ35G_VW36.rod
      VCID: 3449CC1F9F497EB8F5D
      1 Fault Found:
      65826 - No Basic Setting
      B2010 00 [009] - Signal Amplitude Too High
      Confirmed - Tested Since Memory Clear
      Freeze Frame:
      Fault Status: 00000001
      Fault Priority: 6
      Fault Frequency: 1
      Mileage: 0 km
      Date: 2000.00.00
      Time: 00:00:00
      Dealer's VAS told:
      Error ERP0630E - no coding information
      Does anybody has any idea how to overtake it?
      Remarks:
      J518 KESSY is used
      J764 ELV is used (but looks like it successfully adopted - now my VIN is already inside it)
      keys - new, clear, never been coded, but during adaptation keys were not recognized
      Probably I have to use special sequence for adaptation? Next problem that the car is silent, no chance to switch on ignition until successful coding. Any adaptation possible only with emergency lights on.
    2. 10-05-2012 03:22 PM #2
      So your an advanced user which doesn't like to follow directions for the forum.
      Apparently not enough time to read.
      Put your old stuff back in then.
    3. 10-06-2012 06:37 AM #3
      Have you purchase new antennas, keys, door handles and old kessy unit and ELV?? This is very important. I think that with old kessy is important use all old accessories(antennas, door handles). Dashboard is your?? How software version have you in dashboard(kessy support only software 0400 and higher)??
      Important before installation kessy:
      Coding these units:
      BCM(09)
      Steering wheel(16)
      Gateway(19) - add unit on address: 05 and 2B
      Better will be if you do it complete list of all your units in car.
    4. Semi-n00b
      Sep 26th, 2012
      GTI'11
      10-07-2012 06:12 AM #4
      Thank you for support, I'll try follow your recommendations
      Mar 22nd, 2012
      Southern California
      2012 Tiguan SEL w/boost gauge and Scangauge
      10-08-2012 12:43 AM #5
      And ignore Jack, he has unresolved hostility issues. Most of the forum members will answer a simple question in a civil manner.
    6. Semi-n00b
      Sep 26th, 2012
      GTI'11
      10-08-2012 01:37 PM #6
      hrdinaveliky (great_hero - in translation) is really smart guy who gave me a lot of useful advises
    7. 08-31-2014 02:44 PM #7
      Finally I also made Kessy in my car
      All in 2005 car with BKD engine on the board
      Here is a quick movie
      https://www.youtube.com/watch?v=b40w8xfera4
      Only one problem left , door handle
      Touran never build a kessy one, so next chellenge
      Golf Plus / Eos / Tiguan are smaller , and inside door housing is not compatibile
      New door handle will be build this year .... individual one , like everythink
      HOT HOT HOT !!!! MK7 MFSW with CCS https://www.youtube.com/watch?v=JQ8c...ature=youtu.be HOT HOT HOT
    8. Member JUANE DSG TDI's Avatar
      Jul 13th, 2007
      MEXICO
      JETTA 2011 TDI DSG
      03-15-2016 07:39 PM #8
      at last did you got it?
      Quote Originally Posted by mexanicka View Post
      Hello everybody!
      Coding: 030C0C
      1 Fault Found:
      Freeze Frame:
      Fault Priority: 6
      Fault Frequency: 1
      Mileage: 0 km
      Date: 2000.00.00
      Time: 00:00:00
      Dealer's VAS told:
      Remarks:
      J518 KESSY is used
    9. 04-21-2016 02:04 AM #9
      all can be sorted
      no even one error on my system
      all is matched, correct VIN etc
