Results 1 to 4 of 4
Thread: More height for winter tires?
  1. 10-05-2012 03:14 PM #1
    I have a 2009 JSW TDI all stock - running 205/55R16 for summer tires. Buying new winter tires (getting another set of wheels) and would like a little more height without impacting handling or rubbing.
    The chart says:
    The 205/55R16 snows are 24.9" in diameter.
    The 205/60R16 snows would be 25.7" in diameter.
    Tire Rack warns they might rub, although they recommend a maximum 3% increase. Anybody got any experience with the 60's? Am I going to regret buying them? They are actually a bit cheaper than the 55's for some reason.
    Thanks in advance for your help!
    Ron
  2. 10-09-2012 03:41 PM #2
    Bump! More than 80 people have viewed this thread but no one has an opinion if this is safe?
  3. Member Airy32's Avatar
    Nov 14th, 2007
    NC
    MkIV R
    10-09-2012 04:59 PM #3
    No idea if it is safe. Just don't have any first hand knowledge of what works on a JSW. But, based on wheel well clearance on many other VWs I'd say it is more likely it will work than not. But even if it fit I doubt you'd want no extra room in the wheel well for all the stuff that sticks to your tires in the winter.
    You could always compromise a bit and go with a 215/55 or 195/60. I have no idea of availability of tires in those sizes but either would be closer to stock diameter while giving more sidewall. And either of those would definitely work.
  4. 10-14-2012 02:29 PM #4
    Yeah, I'm thinking that gaining 3/8" of height is not worth the risk. I'm sticking with the standard tire size. Maybe I'll just hibernate this winter!
