VWVortex.com - Front Screen - Doesn't Auto Brighten/Darken with headlights
    Results 1 to 4 of 4
    Thread: Front Screen - Doesn't Auto Brighten/Darken with headlights
      May 30th, 2012
      Chicago, IL
      2011 Volkswagen Routan SEL Premium
      10-05-2012 04:35 PM #1
      The front screen doesn't darken or brighten with the headlights/outside conditions.
      I have it set to auto, yet nothing happens.
      Anyone else come across this? I can manually change it in the settings only.
      2011 Calla Lily White Volkswagen Routan SEL Premium
    2. Member PaulAP's Avatar
      May 21st, 2009
      Winnipeg
      2004 MKIV Jetta GLS, 2009 Routan Comfortline 4.0L w/ RSE, 2011 Jetta VI Trendline+
      10-05-2012 06:26 PM #2
      Quote Originally Posted by Chedman13 View Post
      front screen
      Do you mean the instrument cluster or the radio?
      and if you mean the radio, what model? (it's printed on the lower right corner of the radio)
      VW 4 Life... For life, that's what the ex said... but i mean it...
    3. 10-05-2012 10:11 PM #3
      Make sure the instrument cluster dimmer control is not set to maximum brightness (the click past dimming, but before the interior lights come on). In that position the radio's display will also be at maximum brightness and won't use the night colors. If you move the wheel down the radio brightness follows the instrument cluster setting, and will change to night colors when the headlights are turned on.
      George
    4. Member VWroutanvanman's Avatar
      Feb 12th, 2011
      Florida
      2010 Routan Norge SE w/RSE
      10-05-2012 10:12 PM #4
      Do you have the headlight switch set to auto, or the radio set to auto? The settings are changed in the radio: Go to menu, then display settings, and you can change them there, daytime setting, nighttime setting, or auto. At least thats the way on my '10 REN. And I see you mentioned you tried changing it in the settings, but nothing happens. Don't have an answer for you, sorry.
