Results 1 to 2 of 2
Thread: Shifting ?????????
  1. 10-05-2012 07:15 PM #1
    I have a 97 vw jetta trek and I cant put the car into 2nd gear at all, all others I can but have trouble. I have push the clutch then put into gear and then do it again so it can actually get the gear. Oh and 2nd and 4th gear hit the very back part of the square inside the car. Any help plzzz
  2. Member Broke's Avatar
    Aug 13th, 2001
    Columbus, Ohio
    86 GTI 2.0L, 88 Scirocco 16V, 2010 F150 STX
    10-06-2012 02:54 AM #2
    Quote Originally Posted by jetadel View Post
    It sounds like you need to check the linkage or shift cables for slop and worn parts, then re-adjust once the linkage is in good shape.
    020 trans info pages - www.BrokeVW.com
    NEW 0.7619 5th gears for the 020
    NEW 020 reverse gears
    '86 GTI 8V 2.0L -'88 Scirocco 16V - '10 F150 4x4
