Results 1 to 9 of 9
Thread: Need Part Number - Headlight Mounting Screws
  1. 10-05-2012 09:24 PM #1
    Does anyone have the part number handy for the screws that are used to mount the corrado headlights to the upper radiator support? Thank you.
    -Robert
  2. Member crazynorweegian's Avatar
    May 8th, 2006
    Portland, OR
    1990 1.9L G60-ST5 Black, 02 S60 2.4t
    10-05-2012 11:12 PM #2
    They aren't anything special. They are just regular screws. Find something about the same diameter with a semi corse thread from the hardware store. The thread doesn't have to be exactly the same because the holes aren't actually threaded iirc.
    Stephen
    Portland, OR
    Black 1990 1.9L Stage 5 G60 - keeper
    Corrados decay in a way that can only be measured using quantum physics
    http://sites.google.com/site/corradoproject/
  3. Banner Advertiser ZEBLOR's Avatar
    May 31st, 2001
    Tacoma, WA
    1960 SC Bus, 09 GTI
    10-05-2012 11:59 PM #3
    Quote Originally Posted by SLCVR6 View Post
    -Robert
    If no one replies this weekend, I'll give you the PN on Monday.
  4. Member G60ING's Avatar
    Jun 27th, 2000
    Northern MX
    TDI Corrado & Honda Refrig
    10-06-2012 11:11 PM #4
    while you look that up the plastic inserts that screws go into would be killer.
  5. 10-07-2012 12:34 AM #5
    Quote Originally Posted by G60ING View Post
    I can help with that one: 811807577C
    -Robert
  6. Member G60ING's Avatar
    Jun 27th, 2000
    Northern MX
    10-07-2012 09:49 AM #6
    Thank you sir
  7. 10-08-2012 06:14 PM #7
    Bumplestiltskin.
    -Robert
  8. Member CardFan's Avatar
    Feb 22nd, 2003
    Louisville, KY
    05 A4 USP, 90 VW Corrado
    10-08-2012 11:01 PM #8
    The 2 that go in the upper tabs are N0139694
    In the remarks section, B4, 8x16
    And the screw that mounts in the back is N0139729, remarks ST4, 8x25-C
  9. 10-09-2012 09:43 AM #9
    Many thanks for the part numbers! I had the top screw properly identified, but wanted to be positive that was it in the end.
    -Robert
