btw... BB restrictor is suppose to be .035
I received an oil and coolant line kit, everything's a go for fitting (a certain way) & wanted to verify the proper restrictor size for a BB GT2871r being a 0.065mm.
Also, everything fits properly considering the oil pin (restrictor) is facing up (in the air) on the turbo, as there's different thread pitches I can't flip it around to face down. This is the first time I've seen the oil pin on top, as opposed to being downward, screwed into the turbo.
Discuss
FS:Extensively Moddified 350+ hp Mark I to Mark III conversion Caddy truck:
http://forums.vwvortex.com/showthrea...dy-W-Video-10K![]()
FS: Custom '69 Stinger FS: iForged 3 Piece 19x9 5x112 Falken 452's
FS: Custom '73 CB350 Museum Piece, 8 miles FS: 10' V-Twin Chopper: SOLD
2010 MB GLK350 4matic
2009 Gti 2.0t powered by APR (Sold! last VW purchase!)
2001 Gti 1.8t powered by Dalhback (sold and will be missed :') )
1988 Jetta Carat Vr6 powered by www.LugTronic.com (99.9% done!!! )
1987 Scirocco 16v w/t3t4 57trim powered by SDS (sold but never forgotten)
How about the direction of the oil pin?
Yes .035 and it doesn't matter, as far as hole still restricting either way.
.065" is for journal bearing garretts... use the size .035" as others have stated![]()
My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESSPAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
Fantastic, good thing I caught this.
Kinda frustrated as the kit supplier says they'd ship me a .04..that should be fine or only! a .035
Make sure you know the measurements you are talking about.
In the first post, you said it was 0.065mm, then all the guys started talking in inch.
So, make sure you know first if you got your story straight
0.7mm for BB, 1.6mm for journal
0.030" for BB, 0.065" for journal
▀▀▀ EIGH-T6 // "Give me enough traction, and I will spin the WORLD!"
Portugal // Europe
MS II V3.0: http://eight620vt.tk/
Thanks...would that .005 make a difference going from .035 to .040?
Flipping people, sold me a kit supposed for a ball bearing yet gave me a journal kit...and only have the .04 to send.
That, I'm not sure, so I'll not say if it's ok to use or not. Maybe some one used to work with them might chime in![]()
Portugal // Europe
#11
well according to Garrett's turbo FAQ, a minimum of .040" is needed for the DBB turbos. They they go on to say it varies from car to car. You could try the .040", but just be warned you are on the very edge of acceptable. You can read about it here...
http://www.turbobygarrett.com/turbobygarrett/faq
#12
Thanks!
#13
