Results 1 to 3 of 3
Thread: Help! Need clarity?
  1. 10-06-2012 12:41 AM #1
    Im in need of a set of radiator fans for a 2002 2.slow jetta. Dont need a radiator or AC condensor..only the fans. I have an add posted in classifieds w/ paypal ready...
    Question is: Are the electric dual fan shroud/fan setups the same for the 1.8T & 2.0? Im assuming the VR isnt and requires a larger fan setup.
    THE JUST OF IT is, I need a dual fan setup as mine burned out this week due to overheating prob/leaking thermostat...
    If I can use a 1.8T or VR, that will make it easier/quicker for me to find one instead of ONLY LOOKING FOR A 2.0.
    Please post your knowledge!! More the better, looking for confirmation
  2. Member mk4boost's Avatar
    Jul 31st, 2010
    Long Island, NY
    BT Prius
    10-06-2012 08:40 AM #2
    go on ecs and order one for the 2.0 /thread
    F23 Frankenturbo ll Bosch 550cc ll Eurodyne Maestro ll 034 Motorsports High Flow Exhaust Manifold ll Eurojet street FMIC ll Cooling Mist Dual Nozzle W/M ll 287whp, 290ft/lbs (18psi) ll stock bottom end ll
    http://www.frankenturbo.com/
    http://www.usrallyteam.com
  3. 10-07-2012 10:48 AM #3
    thanks for insight. Just went on ECS and did some comparisons. It appears same fan on all 3 engine types per fan details.... Also same for beetle, going trying local scrap yard today.
    IF ANYONE also can confirm, it would be greatly appreciated
