Results 1 to 4 of 4
Thread: MFA Button: Functions, Tips, Tricks and Programming. DIY linked.
  1. Member VrFiend's Avatar
    Sep 18th, 2008
    Iowa
    00 Cabrio GLX, 94 Jetta GLX, 95 Jetta GLX
    10-06-2012 02:52 AM #1
    First off, I dont take credit for any of this. All information was gathered using the search feature. I simply combined it into one useful thread with the answers to the most common questions.
    Functions:
    Switch in position #1.
    1. Present time
    2. Time since startup
    3. Average fuel use
    4. Distance travelled
    5. Average speed
    6. Engine oil temp
    7. Outside temp
    Switch in position #2
    Shows you all the same functions, only it is an overall average since last reset. Position #1 resets everytime the car is restarted. Position #2 only resets when you reset it with the stalk.
    Hidden features and how to access them:
    1.Switch your MFA switch to position 1
    2.Switch your car to "ON" (Don't start it!)
    3.Press and hold the mode button
    4.Turn the key to "Off", then back on.
    5.Release the mode button.
    Now when you cycle through the modes, you get this info:
    -Engine MAP code
    -Country code (1=Canada, 4=US)
    -speedometer drive ratio
    -upper RPM limit
    -lower RPM limit
    -deceleration fuel shutoff pressure (mbars)
    -LCD Test
    And, if you do this:
    1.Switch your MFA switch to position 2
    6.Start the car and drive
    You now get these values:
    -Test checksum of programmed bytes in memory
    -intake manifold vacuum (mbar)
    -engine rpm's
    -fuel consumption
    -signal from speed sensor
    -oil temperture
    -Outside temperature
    If for any reason your ambient sensor goes bad or the wiring goes bad, the mfa will skip over this option. I would assume its the same for the rest of the sensors.
    Using vag com to change the settings: US vs EU readings
    After selecting control module [17-Instruments];
    1- Under "Advanced Functions", select [Recode-07]
    2- Make a note of the 5-digit number in the "Software Coding" box in case you need to reset it. The third digit is the country code and will be the one that is changed. Do not change any of the other numbers, and do not change the workshop code.
    3- Enter the new third digit, select [Do It!].
    The available codes are:
    1 - Europe (24 hour clock, metric units, °C)
    2 - USA (12 hour clock, Imperial units, °F)
    3 - Canada (12 hour clock, metric units, °C)
    4 - Great Britain (24 hour clock, Imperial units, °C)
    5 - Japan (24 hour clock, metric units, °C)
    Note: Japanese gas mileage is calculated differently than other metric countries.
    6 - Saudi Arabia (24 hour clock, metric units, °C)
    7 - Australia (24 hour clock, metric units, °C)
    Europe, Saudi Arabia and Australia appear to all have the same display results.
    DIY To add mfa to non mfa vehicle.
    http://forums.tdiclub.com/showthread.php?t=101455
    http://forums.vwvortex.com/showthrea...&highlight=mfa
    CREDITS/info gathered from
    Izzo
    Alkeli
    tdi28
    Chris Bell
  2. 10-06-2012 07:17 AM #2
    Alot of this is incorrect for the Mk3 MFA.
    Are you from New Jersey, or did you just get the paint job in New Jersey?
  3. Member VrFiend's Avatar
    Sep 18th, 2008
    Iowa
    10-06-2012 02:31 PM #3
    Quote Originally Posted by JohnStamos View Post
    Not really helpful..
    The only thing I havent really checked is the vag com section and the diy install.
    Please correct what is wrong so we can make this a useful thread. Or at the very least, tell me what is wrong and I will try to:
    A. Correct the wrong information.
    B. Remove anything that I cannot find the correct information for.
    Dec 26th, 2010
    Wolfsburg, Germany
    1998/VW/MK3 VR6 Cabrio
    10-06-2012 02:38 PM #4
    The part "Using vag com to change the settings: US vs EU readings". dont work for an mk3. Becurse the mk3 has no diag for Speedo.
    And the "Hidden features and how to access them:" are wrong to. Here is the correct way.
    * Hold the Button for switching between total and session km/miles
    * Switch on the ignition.
    * Turn off the ignition.
    * Release the button.
    * Start the engine.
    Now you have this options:
    1 - distance pulse
    2 - Display mode clock
    3 - DZM code
    4 - Number of cylinders
    5 - Display Test
    6 - encoder for speed
    7 - Tachometer
    8 - Software Version
    Here is a :
    translatet german Page with Speedo-Infos
    Btw. get in NA no 4 Cyl. MFA? I see that the UK Cluster have miles and mfa for 4 Cly but without the options of the NA Cluster (Cel, Seat Bell etc.)
