Results 1 to 4 of 4
Thread: Inspired by the OLD thread, I made some improvements to FORGE diverter valve :)
  1. 10-06-2012 07:30 AM #1
    Back in 2007 you guys had a thread : http://forums.vwvortex.com/showthrea...e-review-(long)
    My personal observations was in line to original poster to some degree. I felt delay in reaction time when use Forge larger valves.
    So, I had a major go on FORGE blow-off valve.
    I was chasing a phantom engine power flactuation during the throttle drop from WOT to 50-70% above 5000RPM. It would cause engine power to surge, very annoying.
    So, I machined a new lightweight piston (60% lighter) and cap with a larger nipple for bigger house. Also, reduced working volume of air under the cap by some 50%, by blocking off empty space inside piston.
    Result is smooth predictable power transition with much faster boost/vacuum transition. No more engine jerking as per above condition.
    Some details on Forge Valve Modifications are here. Below are some images.
    .:R32T, Stock Internals | Precision 6265 | Schrick 268/272 | SRI by UM | DSG & Engine Code by UM | Side mounted oil cooler | 3.5 inch exhaust |
    Looking for Sheet Metal Fabricator? Talk to me!
  2. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    10-06-2012 02:10 PM #2
    that's pretty neat!
    I would love to see some logs between the normal forge unit and this.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  3. Member Randomdub's Avatar
    Jun 15th, 2008
    Portland, OR
    1983 Rabbit GTI
    10-06-2012 04:06 PM #3
    Quote Originally Posted by Krieger View Post
    that's pretty neat!
    I would like to see this also. Then give us a price point
    "Defeat is not the worst of failures. Not to have tried is the true failure!"
    -George E. Woodberry
  4. 10-07-2012 01:41 AM #4
    Quote Originally Posted by Randomdub View Post
    Logs - I cannot see the way to collect them. There is no sensor in the engine that will measure timing delay between throttle plate angle change and pressure drop BEFORE throttle body.
    Its VERY evident once you install new parts and watch boost gauge and get use to new throttle behaviour, there is no LAG there any more. It keeps impeller spinning as it releases pressure when needed instead of allowing it to rise between turbo and closed throttle plate for some short time while stock/heavy piston build up momentum and start moving.
    Cost - PM me if interested. But keep in mind, it's more than a cost of the whole Forge Valve
    Custom CNC machining in low QTY do not come cheap. I threat it as expensive R&D.
    BTW, you can buy new cap direct from FORGE with large feed nipple for much less.
    I wanted mine to have different finish for improved hand grip, so made my own. No reason to use it over Forge part really.
    You would only need this modification if you are:
    In competition Motorsport, when it matters
    If you are chasing OEM like behaviour with improved air flow of Forge Valve
    I bet you Forge can machine them to, if demand is there. It's nothing special really, other than time consuming to machine (read expensive).
