Results 1 to 20 of 20
Thread: Exhaust tips don't fit! Help please
  1. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    10-06-2012 11:25 AM #1
    So I bought some exhaust tips for my 2013 CC. Much to my surprise they don't fit!
    If you look in the third pic, it seems as if the car already has some tips installed, albeit not chrome ones. Do I have to remove them (wouldnt know how cause they seem to be welded to the exhaust) and then be able to fit the chrome tips? Or did the ebay seller just send me the wrong ones?
    Apr 20th, 2011
    Southeast Florida
    2012 VW CC R-Line w/DSG
    10-06-2012 11:36 AM #2
    I had to bang mine on with a rubber mallet. They are a 'scrape fit' so they don't rattle. The two tips will be almost touching each other when installed. Then again I had OEM and your's are not.
    Larry
    2012 CC R-Line, DSG (stock)
  3. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    10-06-2012 11:43 AM #3
    but it looks like the exhaust itself is round, whereas the "factory fitted" tips (as seen in the 3rd image) are oval. Is this normal or does my car have different ones than the ones sold in the US (I live in Dubai).
  4. Junior Member BiGWAM's Avatar
    May 5th, 2012
    2013 Sport Plus CC, 2010 CC (sold)
    10-06-2012 12:14 PM #4
    My 2013 has the same exhaust as yours. You need to buy the OEM tips. They will fit over the existing exhaust. I bought mine from the dealer for around $50. US. The tips have to be for the CC. The first set the dealer sold me were for the jetta and would not go over the exhaust. The second set he sold me were made for the CC and fit great.
    2013 Sport Plus CC (James Bond Edition) -- Debadged, 35% Tint, EZ-Lip, K&N filter, Blacked out Grille slats, Euro-Switch, Hoen-Xenonmatch Fogs
  5. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    10-06-2012 01:14 PM #5
    Thanks. I am glad to know that my car isn't different because of the OEM oval tips. Will try to get the chrome ones from the dealer, that is if they sell them out here.
    May 5th, 2009
    Vancouver, BC
    2010 Passat CC 2.0T 6MT
    10-06-2012 02:04 PM #6
    I noticed the tips you have are the clamp type. Are they by any chance these ones from ebay? http://www.ebay.ca/itm/120957379042?...84.m1497.l2649
    Because I have those ones and they fit over my exhaust perfectly, with just the right amount of elbow grease needed get them all the way in:
    If you have the same ones, then it's likely 2013 cars have different dimensions.
    The exhaust pipes are round, they just appear oval because they're cut at an angle.
  7. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    10-07-2012 04:21 AM #7
    Quote Originally Posted by boogiedownberlin View Post
    So I bought some exhaust tips for my 2013 CC. Much to my surprise they don't fit!.....
    did the EBAY seller just send me the wrong ones?
    You already know the problem
    2013 VW
  8. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    10-07-2012 10:28 AM #8
    Quote Originally Posted by baye View Post
    I got it from a different seller. heres an image of it;
    May 5th, 2009
    Vancouver, BC
    10-07-2012 01:17 PM #9
    That looks way too short (and it shouldn't narrow on the end there, see my link for comparison). Are you sure the listing say its compatible with the CC? I'd contact the seller for some kind of exchange or refund because there's no way that is going to fit on your exhaust.
    For the record, eBay is a very safe place to buy from. I've purchased many things there that worked perfectly, zero failures, and cost only a fraction of what they go for elsewhere. You just have to be careful and double check the descriptions before buying. The sellers are typically really responsive and helpful if you have a problem because reputation is super important to them. The only inconvenience is shipping really.
  10. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    10-07-2012 02:07 PM #10
    Yeap, the listing said it would fit VW CCs (the 2.0T models). I have contacted the seller and I am sure he will refund me the money (they always do since they are scared of a bad rating).
    I also have to say that I have done over a 100 transactions on ebay and am very satisfied with all purchases and sales. This is the first time that I have received the wrong item.
  11. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    10-08-2012 06:20 AM #11
    Ebay "can" work BUT what you have there is a pretty crappy exhaust tip
    I've NEVER seen an exhaust clamp with a worm drive/hose clamp
    The VW exhaust tips are help on by set screws, which aren't that pretty (because they poke out a little) but work 100%
    A nicer tip will have a band clamp connection on it though
    2013 VW
    May 5th, 2009
    Vancouver, BC
    10-08-2012 12:03 PM #12
    I get what you're saying but I couldn't care less what kind of locking system is used as long as it works. Mine go on so tightly I couldn't yank them off even without the clamps tightened. I've had them for a while now and they've been just fine. Maybe they should start disintegrating just to fit the made in china stereotype.
  13. 10-27-2012 12:22 AM #13
    does VW sell chrome tips for a 2009 CC sport?
    id rather get hi quality one that fir rathter tan "make it work type"
    any part numbers? thanks
  14. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    10-27-2012 09:39 PM #14
    Quote Originally Posted by roblinds View Post
    Yes
    http://keffervwparts.com/eCatalog/in...iteid%3D216177
    2013 VW
  15. 10-28-2012 09:14 AM #15
    cool thanks-- just picked them up along with some nice mats too thanks..
  16. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    12-02-2012 12:59 PM #16
    Quote Originally Posted by snobrdrdan View Post
    Snob, you sure these are the ones that fit your CC and your CC has the same exhaust as mine? I would like to orrder the same set, but on the link you provided it says 09-12
  17. Member sm0421's Avatar
    Mar 13th, 2008
    Reading, PA
    13 CC 6-speed, Island Grey
    12-02-2012 03:01 PM #17
    they would 100% fit and the cost from me was $38 from Douglas VW, I picked'em up, shipping would be $10.
    2013 CC Sport 6-speed | Island Grey | Cornsilk Beige | Diesel Geek Short Shifter | Cornsilk Shifter Boot | Aluminum Pedals | Chrome Exhaust Tips
  18. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    12-03-2012 02:11 PM #18
    Bought it. I just hope it fits my car. This will be the third set I am getting
  19. Member
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    12-03-2012 09:33 PM #19
    it looks like the stock tips are pressed on (there is a dent for it) and a quick spot weld.
    I wonder if it is possble to grind away the weld and remove the stock tips?
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  20. Member snobrdrdan's Avatar
    Sep 9th, 2008
    Southeast Michigan
    2013 VW
    12-09-2012 05:00 PM #20
    Quote Originally Posted by BsickPassat View Post
    I think that's plausible
    2013 VW
