That's unluckymy gf washed mine and luckily it came out working fine.
#1
And along with it, my key fob. After losing my spare. And my other spare. So now I'm left with no functioning keyfob
Any suggestions to programming and which (if any) board I need to find to replace it? Immo wasn't affected, so it would just be replacing the circuitry and reprogramming to the central locking system.
#2
#5
if you replace the battery does the light still blink when you push the button? maybe try to re sync it.
put in door unlock, and hit lock or unlock with in 30 sec.
it worked for me..
worth a try.
#7
Mine broke too. I went on ebay, found a reputable seller and then reprogrammed it with VCDS
#8
#9
Thanks guys. It's functioning except will randomly will hit my panic button now. What price range am I looking at?
#10
#11
Dry it out really good and put in a new battery. I've done this too and have no problems with the current fob, except it doesn't quite have the range that it use to have.
Imy jetta
#12
leave key in pants.. blame girl for doing your laundry... like a boss
#13
My key fog has been through the washer/dryer twice and still works perfectly.
