Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 102
Thread: Puddle Lights - DIY (a piece of cake)
  1. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    10-06-2012 04:12 PM #1
    Alright, I swapped out my bulbs yesterday with LEDs.
    The process takes about 5 minutes for each side.
    Tools required:
    1- Angle wrench (see pics) or a similar angled tool
    2- Cloth
    3- Screwdriver with torx bits
    4- Size 194 LED bulbs
    Detail Steps:
    1- Wrap the curved part of the wrench with the towel.
    2- Tilt mirror all the way down, and place the angled wrench behind the mirror and pry out, use a quick nudge, usually two nudges will do it. Do not attempt to do this on the sides of the mirror, left or right...that's where the cracking will occur.
    3- Unscrew the 3 torx screws holding the tilt module in place. Have pliers ready to catch the screws. Screws falling into the mirror housing will no longer be a quick job.
    4- Tilt module is now out. Pull out the black wire housing (the thick housing with the white sticker around it, that's holding all the wires together) from the plastic clip for better access. I'm pointing to the clip below
    5- The blue and green wires connect to the bulb harness that needs to be removed.
    6- Pull out the bulb harness with pliers. Be extra careful and do this slowly. My first time, the bulb came lose and fell inside the light housing. I ended up taking apart the entire mirror assembly to remove it.
    7- Here is he 194 bulb.
    8- Swap it out with your LED bulb and open the door to make sure the bulb lights up before putting it all back together! LEDs have poles, so if it doesn't light up one way, turn the bulb around and put the base in the other way.
    Put everything back together and you will now enjoy this quick mod the next time you unlock or open the door.
    And here is the bulb I used. Size 194 from eBay. I bought a dozen of them for $4.99
    '12 CC Lux Ltd....
    May 5th, 2009
    Vancouver, BC
    2010 Passat CC 2.0T 6MT
    10-06-2012 04:26 PM #2
    Great writeup. Although I fear If I do this I'll end up wanting to match all the other lights (license plate, interior, etc.) too.
  3. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    10-06-2012 04:44 PM #3
    I hear you!! In my case my car throws error codes if I try to swap any other bulb, so when that happens I just use Hyperwhite bulbs as I did on my license plate. They are not as white as LEDs, but a hell of alot better than yellow! So color wise my plate doesn't match my puddle lights 100%, but I'm ok with that...nothing in life is perfect
    '12 CC Lux Ltd....
  4. Member
    Feb 25th, 2012
    Queens, New York
    09 VW CC
    10-06-2012 07:52 PM #4
    Great detailed write up with pics.
  5. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    10-06-2012 08:01 PM #5
    Quote Originally Posted by Los1 View Post
    I try to make it as easy as possible
    '12 CC Lux Ltd....
  6. Member
    Aug 8th, 2012
    Chicago, IL
    Audi A4'97--> Subie WRX'07 Stage 3+--> Murano--> VW GTi'11--> VW CC 2011 now
    10-06-2012 09:40 PM #6
    No No No!!! Itsnt going to work, buddy!!! I want some DSLR n HD shots in here
    2011 PaCCaT "Hybrid": WT 30%, Dectane Headlights, 100%Clear Frnt Turns, R-Steering Wheel, R Door Sills, 4300K USP, LEDs, Stance 6ix, Eibach Pro, Hotchkis 27mm RSB, BSH Torque Mnt, Full Carbonio AI .
    __________________________________________________ ________________________
    In Process: Led Footwells(rear), Brembo Gold Caliper Paint w/ VW Decals. WTB:
  7. Junior Member Grajjie's Avatar
    Sep 30th, 2012
    New York City
    2013 CC 3.6L Executive Black/Black
    10-06-2012 11:16 PM #7
    Very nice and detailed write up. I will definitely be doing this soon.
  8. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    10-07-2012 12:19 AM #8
    Great, good luck!
    '12 CC Lux Ltd....
  9. 10-07-2012 08:51 AM #9
    Did you try error free LED's? Just google it and you will find plenty of LED's that are designed for European cars
  10. 10-07-2012 08:53 AM #10
    Quote Originally Posted by KOWCC View Post
  11. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    10-07-2012 08:01 PM #11
    The puddle lights do not get tested by the CECM. I did not get any errors. However I've purchased several sets of error free bulbs for use around my car and they were specifically designed for VW and all claimed to be error free. They STILL throw an error code. It just won't take any LEDs. Tried about 10 sets for my plate, literally 10 sets, even tried resistors. Believe me I have toooo much experience with this and they don't work. Even bulbs from ECS and Pyspeed who guaranteed me no codes, still threw codes. Specifically the 2012 lux limited trim has an upgraded CECM over the other trim packages due to its internal ambient lighting. That trim hates LEDs. All my friends with 2012s that are lower than the the lux limited use the same bulbs without errors.
    '12 CC Lux Ltd....
  12. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    12-17-2012 10:53 PM #12
    So I got the LED lights today. I do however have a question, before I start taking my mirrors apart. I know how I have to take the mirror off (basically the first step of the whole process), but my question is how do I put it back in there again? Glue?
  13. Member
    May 5th, 2009
    Vancouver, BC
    12-17-2012 11:52 PM #13
    Quote Originally Posted by boogiedownberlin View Post
    The mirrors are held in by small clips, so you can just simply pop them back in again. Easy.
  14. Junior Member
    Sep 3rd, 2012
    Abu Dhabi
    2013 CC 2.0T
    12-18-2012 01:13 PM #14
    Did it today. Was a bit scared on the first mirror and took over 15mins, but the end one took like 5 minutes. Thanks for the instructions and help guys
  15. Member
    Feb 25th, 2012
    Queens, New York
    09 VW CC
    12-25-2012 03:50 PM #15
    Well I managed to get the mirror off without cracking it relatively quick due to this great write up but the darn led light bulb fell in the small light housing. Are there any solutions to retrieve the bulb without taking apart the entire housing?
    Any help would be greatly appreciated.
  16. Member
    Nov 28th, 2009
    LA, CA
    2013 CC Sport with Light - Island Grey
    12-25-2012 07:32 PM #16
    Actually the housing can be popped out
    If you push it firmly it will be come off
    There is holding tap inside of housing so you can push in the outer side of the lamp housing
  17. Member
    Feb 25th, 2012
    Queens, New York
    09 VW CC
    12-25-2012 08:03 PM #17
    Thanks for the info. I will give it a shot this weekend.
  18. Junior Member
    Dec 26th, 2012
    SoCal
    2.0T CC DSG
    12-26-2012 12:58 PM #18
    same here. i'm going to try this soon. great diy instruction .
  19. Member DasCC's Avatar
    Feb 23rd, 2009
    Monterey Peninsula
    2012 VW CC R-line
    12-26-2012 06:50 PM #19
    solid writeup
  20. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    01-17-2013 10:54 PM #20
    Thx guys, glad it helped!
    '12 CC Lux Ltd....
  21. Member Joef1sh's Avatar
    Feb 5th, 2010
    Dallas, TX
    2009 CC VR6 4Motion
    03-03-2013 01:44 PM #21
    Well THAT was an expensive mistake...
    Word of warning: Do NOT use a flathead screwdriver (all I had) to attempt to remove the glass. I wrapped mine in a thick terry cloth and it still cracked both mirrors. I should have learned my lesson the first time, but even trying to pry it from a different location, it cracked anyway.
    I removed the glass from my MKV Jetta the same way and it was a piece of cake. I seriously think VW used thinner glass on these CC's. I barely nudged them and this is the result.
  22. 03-03-2013 07:40 PM #22
    Great write up and now bookmarked on my phone. I will be doing thins in the next few days.
    Thank you KOWCC
  23. Member
    Feb 25th, 2012
    Queens, New York
    09 VW CC
    03-03-2013 08:06 PM #23
    The write up is definitely great. I broke a mirror on the first attempt and then I decided to give up. I ordered the blue tinted aspherical mirrors and give it a second try with much success. I used a plastic angled pry tool that I purchased from my local auto store and followed the steps from the write up.
  24. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    03-03-2013 08:19 PM #24
    Quote Originally Posted by Joef1sh View Post
    That's why I used that tool buddy. It has much more surface area than the flat head (its all about surface area, to spread the force) plus it has than angle, so the force is only directed straight outwards.
    '12 CC Lux Ltd....
  25. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    03-03-2013 08:19 PM #25
    Quote Originally Posted by Will22 View Post
    Thank you KOWCC
    Will, any questions let me know...here to help.
    '12 CC Lux Ltd....
  26. Member
    Feb 25th, 2012
    Queens, New York
    09 VW CC
    03-03-2013 08:29 PM #26
    You know your stuff. Thanks for sharing as you have helped me out in the past.
  27. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    03-03-2013 10:05 PM #27
    Anytime brother.........I'm here to learn as well.
    '12 CC Lux Ltd....
  28. Member BORA RSI's Avatar
    Oct 18th, 2001
    Chicago burbs
    09 VW CC
    03-03-2013 11:08 PM #28
    @Joef1sh Why not use your fingers to pull them instead. That's what I have done to mine and two others works better imo. Now you can upgrade them at least
    OEM+
  29. Member Joef1sh's Avatar
    Feb 5th, 2010
    Dallas, TX
    2009 CC VR6 4Motion
    03-04-2013 01:21 AM #29
    I tried, but couldn't get enough grip on them to pull them off. Even with them tilted all the way down. I didn't want to drive around without mirrors while a set of blind-spot's would have to be shipped, so I just swung by the stealership and got another set. I'll chalk this one up to being ill prepared. I picked up a nice set of trim removal tools this weekend, so I won't make the same mistake...uh...3 times.
  30. Member MikeinNJ's Avatar
    May 8th, 2007
    Central Jersey
    13 CC R-Line, 2009 Rav4 (Sold), 2011 CC Lux (Sold), 07 Jetta Wolfsburg (Sold)
    03-07-2013 06:46 PM #30
    Just did mine with the 194 bulbs from superbrightleds. Looks awesome! No glass broken either.
    Though, I did the driver's side first and when I was squeezing the bulb socket back into it's housing, the bulb came out of the socket and fell inside the housing. Had to disassemble the whole mirror in the middle of the rain/snow storm we're currently having to fish it out and start all over. Got it in ok, then hooked the mirror glass back up and sealed it up. Then realized that I didn't tuck the harness back under its hook. Had to pull it again. The passenger side, I was done in about 10min. Yes, it's also dark out right now. Yes, I am nuts. So worth it though!
  31. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    03-07-2013 07:40 PM #31
    Quote Originally Posted by MikeinNJ View Post
    Lol, we are all nuts....nothing at all stops us....I gotta say for me personally nothing stops me from working on my car, except for darkness...I must have light!
    '12 CC Lux Ltd....
  32. Member MikeinNJ's Avatar
    May 8th, 2007
    Central Jersey
    03-07-2013 09:07 PM #32
    KOWCC, for your Sencart puddle lamp bulbs, do they fade in/out like the incandescents do or do they have a sort of stepped, digital fading? The ones that I got from superbrightleds do an almost flickery, stepped dimming on and off. Also, they are definitely not as bright as the ones you posted in the other thread. They are about the same light output as stock, maybe a bit more, but do have a nice cool white color temp.
  33. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    03-07-2013 09:18 PM #33
    KOWCC, for your Sencart puddle lamp bumps, do they fade in/out like the incandescents do or do they have a sort of stepped, digital fading? The ones that I got from superbrightleds do an almost flickery, stepped dimming on and off. Also, they are definitely not as bright as the ones you posted in the other thread. They are about the same light output as stock, maybe a bit more, but do have a nice cool white color temp.
    Yes same style fading in/out as you described....not a consistent soft fade in/out, but almost like a flicker on/off... When they flicker the light never turns off completely, but its like a digital in and out exactly as you described....yes the sencarts are extremely bright.
    '12 CC Lux Ltd....
  34. Member MikeinNJ's Avatar
    May 8th, 2007
    Central Jersey
    03-07-2013 09:22 PM #34
    Ok, thanks! Also, I wouldn't mind that extra brightness, though I know I would really be chancing it to change these bulbs out TWICE without losing any screws or cracking the glass.
  35. Member KOWCC's Avatar
    Mar 30th, 2012
    SE MI
    12 CC LUX LTD - DSG
    03-08-2013 12:56 AM #35
    After the first time, it's a piece of cake.....done it a handful of times
    '12 CC Lux Ltd....
