Results 1 to 7 of 7
Thread: Temp Gauge Sender Location
  1. Member vwbugstuff's Avatar
    Mar 27th, 2004
    NW Chicago 'Burbs
    2012 CC "R"-Line, 2003 Eurovan, 1979 Westfalia, 1978 Superbeetle Convertible, 1998 New Beetle
    10-06-2012 04:55 PM #1
    '92 Jetta GL 1.8
    I'm working on the boy's car - where is the temp sender/sensor for the coolant temp gauge on the dash? And, what colors are the wires that go to the plug for the aforementioned sender?
    Pictures would be extremely helpful.
    Thanks in advance!!!
  2. Member adam the caveman's Avatar
    Sep 9th, 2010
    marysville, wa. USA
    Euro Nation monty16vT project (Mildred), Mk3 jetta, mk3 cabby 'highline'
    10-06-2012 05:40 PM #2
    for the coolant temp gauge?
    its on the coolant flange coming off of the front side of the cylinder head. right in the middle.
    i haven't messed with a digifant in a while so i forget which one.
    "Thinking about selling my hood since it's always open anyway"
    "Huffing which flavor of industrial strength, brain rotting solvent is en vogue this week?" - Seax_Smith
  3. Member Seax_Smith's Avatar
    Jun 1st, 2007
    Not Present.
    Newest, 92 GTi half-swap plus
    10-06-2012 07:37 PM #3
    Dead center front of engine. The flagne is the other end of the upper radiator hose. There will be 2 sensors on top. Blue one should be toward the head and is the CTS for the digi II. The black one on the outside, is for the water temp gauge.
    Funny thing both are heat activated resistance switches with different curves. The more expensive CTS goes bad regularly, and the less expensive temp gauge send almost never goes bad.
    Thanks for calling. Your call is very important to me. If you would like to reach me by phone now, please hang up now. If you would like to reach me by phone later, please hang up later. If you would like to speak with a person, please press ten. ..... I'm sorry I do not understand one zero. Please hang up now or later if you cannot press ten.
  4. Member vwbugstuff's Avatar
    Mar 27th, 2004
    NW Chicago 'Burbs
    10-06-2012 11:59 PM #4
    Thanks for the replies guys!
    Here's another then: on the right side of the block (driver's side) there is a flange for one of the heater hoses. There is a white, 2-prong sensor in that flange as well. What is that one for? It's not plugged in and there is no plug floating around that could plug into it. But there is a dangling wire, which is long enough to reach it, grounded to one of the valve cover bolts.
    And, just ranting out loud, who's brilliant idea was it to put the thermostat where it is? What a total pain in the a$$......
    What is the cooling system capacity so that I know how many litres of G11 to buy???
  5. Member Seax_Smith's Avatar
    Jun 1st, 2007
    Not Present.
    10-07-2012 09:13 AM #5
    Digi II does not have a sensor in the side head coolant flange. White 2 pin sounds like a CE1 Digi II CTS which would match up with the early type, aluminum, front flange. Possibly it is an add-on for an actual water temp gauge.
    Wires grounded to the head in that area: The coil bracket should have a ground strap or 12 gauge connection it to the head. There is Also the after run switch that will have a brown wire sheathed in black. This turns on the fans when the bay temp reaches outragiously high temps. It is usually removed because it is mostly useless and gets in the way.
    Grounding the low pressure oil sender wire happens sometimes too.
  6. Member vwbugstuff's Avatar
    Mar 27th, 2004
    NW Chicago 'Burbs
    10-07-2012 01:57 PM #6
    I'll post some pics tomorrow.
    Any ideas on the cooling system capacity?
  7. Member Seax_Smith's Avatar
    Jun 1st, 2007
    Not Present.
    10-07-2012 08:17 PM #7
    about 2 gallons
