Results 1 to 15 of 15
Thread: Looking for cf hood advice.
  1. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    '04 R, '10 Jetta TDI
    10-06-2012 04:58 PM #1
    I need a new hood and realize a cf hood might be cheaper than buying a new oem hood and dealing with paint and the paint matching. At one point I saw blue weave curious if anyone has pics of the blue weave on a dbp. Also curious of the brand who makes the blue weave.
    I've found a few brands of cf hoods and curious which are the better brands to look for. Which is the most durable and which is the lightest? What are the weight savings? Where is the best pricing?
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  2. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    10-06-2012 07:38 PM #2
    I found three different colors of blue. Thinking royal blue might match the closest.
    http://www.deftracing.com/carbon_fib...d_mainlist.htm
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  3. Member horribleR's Avatar
    Feb 1st, 2010
    CA
    2004 VW R32, Miata hardparker
    10-06-2012 07:51 PM #3
    I still think EuroGear hoods are the way to go.
  4. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    10-06-2012 09:01 PM #4
    I have found some really nice reviews on euro gear hoods. But seem to only find seibon hoods for sale in classifieds.
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  5. Member zmoney's Avatar
    May 22nd, 2005
    Pacific Beach CA
    04 R32
    10-07-2012 11:46 AM #5
    Read this:
    http://forums.vwvortex.com/showthrea...ighlight=candy
    I have it now and the color/hood have held up very well.
    May 24th, 2011
    SoCal and El Paso, TX ;-)
    MKIV.:R32 & MKVI.:R (Spring '13)
    10-07-2012 06:34 PM #6
    I'm rocking a Seibon Hood and I love it. Don't worry about what is the lightest. 3-5 pounds difference means nothing when you have you engine and drivetrain over the front axle. Look at durability and fitment. Do your self a favor and have a body shop fit it (Unless you can do great autobody and have tools). Fitment will never be 100%. The shop I use took 6 hours and a lot of TLC to get it about 95% of OEM.
    UNDER STEER MUST DIE!!!
    As my skills/abilities increase UNDER STEER magically disappears!!!
  7. Member Yak Meat's Avatar
    Sep 28th, 2011
    NH
    04 R32, 00 A4 1.8T, 88 911 Targa
    10-08-2012 09:45 AM #7
    Id say between moving the battery and getting a cf hood, those ~40ish lbs off the front is worth it and noticeable...
    So who has the best fitting and durable hood?
    Garage Sale
    Nothing makes sense on this forum anymore. So I'm going to go masturbate.
    Jul 3rd, 2010
    Devon, England.
    10-08-2012 04:51 PM #8
    Quote Originally Posted by Yak Meat View Post
    Must be the best part of 1000kg over the front axle area. 40lb is 18.18kg which is 1.8% of the weight over the front axle. Every bit helps but i very much doubt 99.9% of the people on here would ever notice the difference that the weight was removed if you didn`t tell them. If you drive your car with a friend say 180lb + in the passenger seat and the car doesn`t feel off balance etc your sure as hell not going to notice 40 lb. Just my opinion
    585 flywheel bhp HPA blackjack turbo conversion. Forged engine,ported head,+1mm Ferrea valves + spring,Schrick 268/264 cams,Vibratechnic engine mounts + dogbone,DRP gearbox,Clutchmaster FX850,Quaife up front and Peloquin in the rear etc etc.
    DRP gearbox`s and R32 rear diffs always for sale
  9. Member Yak Meat's Avatar
    Sep 28th, 2011
    NH
    10-08-2012 08:15 PM #9
    I think I would notice it... but thats just me.
    Garage Sale
    Jul 3rd, 2010
    Devon, England.
    10-09-2012 07:41 AM #10
    As long as you or the buyer of any product is happy that is the main thing. Personally i believe there are a lot of hyped expensive products on the market that people buy like sheep as they read people trying to justify why they just spent hundreds of dollars and many hours fitting something that makes very little if any difference to anything other then a track car where every tenth of a second and few pounds in weight matter.
  11. Member Yak Meat's Avatar
    Sep 28th, 2011
    NH
    10-09-2012 12:48 PM #11
    Its all going to help.
    Look at the new volkswagen/audi platform. They shaved a few lbs here and there but across 50 or so systems, they removed 220lbs from the car overall.
    So, if you combine light weight wheels, brakes, get the USRT control arms for the 2 lbs savings, a CF hood, move the battery to the rear, remove the SAI, you could shave over 60lbs rotating (brakes and rims) and another 50lbs or so from the front of the car...
    Hood is removing ~ 20lbs
    Battery is relocating ~ 20lbs to the rear
    SAI removes ~ 7lbs i think all said and done
    Control arms save 2lbs a side i believe (might be 2 overall)
    If you got into changing seats, you could save like 30lbs each...
    In you were crazy you could get the ultra light suspension from H&R...
    Pull off the engine covers and reroute some systems to remove material
    I know someone who has shaved like ~ 30 lbs from the cars wiring harness (race car)
    End of story:
    So u can easily remove 50lbs from the front of the car and even more if u want to spend real money and get crazy... Thats definitely noticeable.
    Every little bit helps.
    Garage Sale
    Jul 3rd, 2010
    Devon, England.
    10-09-2012 05:36 PM #12
    My car is stripped and like you say every bit helps. It just comes down to how much money people want to spend for the benefit gained and hassle involved plus troubles it causes down the line.
    If you remove the sound deadening material from the hood you only save about 10lb with a fiberglass/carbon hood if that. Nearly everyone i know that has a carbon hood admits it was a a PITA to fit and never fitted properly same as carbon wings etc. Plus they crack easy etc
    I have a light weight battery fitted up front. Putting the battery in the rear moves the weight to the rear but then you also have added best part of 15-20 in extra weight with the thick cable needed to run to the rear.
    SAI removed as it`s a piece of crap that kept getting in the way to be honest
    Control arms. How much to save 2lb and hassle involved....
    Seats changed and rears removed.
    People remove the aircon to save weight but i would rather be comfortable driving when it`s hot then sweating my nuts off when driving around town or on the road.Like i said each to there own but unless a track car 99.9% of people would notice on here with most of this stuff done after spending several thousand dollars on doing so. Personally one of the best steering/handling mods i have done is remove the OEM steering wheel and fit a snap off 330mm wheel. Much better grip on the wheel with less turning plus the wheel doesn`t flex .
  13. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    10-13-2012 09:53 PM #13
    Not looking so much for weight savings but rather I need a hood and keeping a carbon fiber hood as option. Granted weight saving is still nice. I did get a spare DBP hood. But it's not lining up right. Looks like I might need a new latch and right side sits high. Still thinking about a cf hood, but don't really want a black hood on a blue car. Might check out the deft racing blue black cf hood. Undecided.
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  14. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    10-14-2012 04:40 AM #14
    everyone says Eurogear is the way to go, I offer no actual help, but Eurogear seems to have the best fitment from what ive seen in person and in the pcitures on here.
  15. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    10-14-2012 09:51 PM #15
    Fitment is everything. I found a used DBP hood in ok shape, and I'm still trying to get it right.
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
