Results 1 to 26 of 26
Thread: First service debacle
  1. 10-06-2012 06:26 PM #1
    Took my TT to the dealer yesterday for the 15k mile service. Parked the car in the garage last night and left early this morning for work. Returned home an hour ago to find this on my garage floor. Of course the service dept has closed for the day and won't be back until Monday. Now I will have to travel over 100 miles round trip to have them correct this. What a waste of my time. Not a very good way to start my Audi service experience.
  2. 10-06-2012 06:29 PM #2
    Pics
  3. 10-06-2012 06:32 PM #3
    Can't seem to get images to stick. Needless to say, there is a 3 foot by 1.5 foot puddle of oil on the garage floor.
  4. Member
    Oct 16th, 2008
    MA
    2012 Audi TT-RS
    10-06-2012 06:41 PM #4
    2012 Audi TT-RS
    Options: Suzuka Gray, Tech Package, Sport Exhaust Titanium Package, Heated Seats, CF Mirrors
    Mods: Scorpion Secondary Cat Delete Pipes, 034 Downpipe, 034 Rear Sway Bar and End Links, United Motorsport Stage 2, Escort Passport 9500ix (Hardwired)
  5. Semi-n00b keepryt's Avatar
    Aug 25th, 2012
    CT
    2012 Audi TT RS
    10-06-2012 07:05 PM #5
    If your drain plug is loose I wouldn't drive 100 miles, it might fall out and your engine will seize. See if you can tighten it yourself first or drive to the closest shop.
    2012 TT RS, UM tune, sport exhaust
  6. Member
    Jul 14th, 2000
    Bay area, California
    2012 TT-RS
    10-06-2012 08:38 PM #6
    That's not good. What model TT is it? Definitely don't drive it without checking the oil level / taking a look under the car to tighten up any drain fittings. Ask Audi to tow it if necessary.
    2012 TT-RS in Suzuka Gray
  7. 10-07-2012 06:15 AM #7
    Quote Originally Posted by Marty View Post
    It is a 2011 TT.
  8. Member GaBoYnFla's Avatar
    Oct 2nd, 2005
    Florida
    2011 Audi TTS
    10-07-2012 08:12 AM #8
    You need to make sure it has enough oil....check it and see if the oil is coming from the plug or the filter....tighten which ever it's coming from. Not a good start to a good relationship.
    Look under your car to see if that much oil is coming out, it's probably all under the undercarriage of the car too-make them clean it all off! What a mess!
    Good luck.
    What dealer is it?
    It's me, it's Earnest T!
    2011 Audi TT S
    Black on Black
    Clear bra, H&R Sport Springs, Magride, Neuspeed 25mm front and rear sway bars
  9. Junior Member
    Jun 28th, 2012
    Doylestown, PA
    2013 TTRS Red Tech Pkg Alumi Optic Pkg Heated Seats
    10-07-2012 08:49 AM #9
    DO NOT START YOUR CAR without checking the Oil Level
  10. 10-07-2012 09:01 AM #10
    Quote Originally Posted by GaBoYnFla View Post
    Good luck.
    What dealer is it?
    Oil at low end of normal this morning. Will ask dealership, Audi of Wilmington, to trailer the car back to the dealership to address and clean the underside. Will also request a loaner car while this is being performed. The worst part is that I live on-base, I'm in the Air Force, and will have to clean the garage floor. I have cardboard under the car right now to reduce further mess. Any tips for cleanup -- kitty litter, Simple Green? May be too late for kitty litter as it has already soaked into the concrete.
  11. Member 3G3T7I's Avatar
    Sep 30th, 2005
    Exeter Twp, PA
    German cars
    10-07-2012 11:11 AM #11
    Well that's not good! I would go with having it flat bedded to the dealer and they maybe can deliver the loaner when they send the flat bed.
    I would definitely use Simple Green to remove the stain after absorbing the oil. Good luck and if it's a fairly new concrete surface it might have a stain resistant coating. Please follow up with your outcome and treatment by the dealer.
  12. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    10-07-2012 12:19 PM #12
    Audi of Wilmington in DE?!?!?! If so, I've had nothing but good service from them for years. This is really surprising if it is them.
    2012 TTRS: Daytona Gray, Tech Pack, Heated Alcantara, CF Mirrors
    Go Mods: GIAC Stage 2+, AWE SwitchPath, AWE cat-deletes, AWE FMIC, H&R RSB, MSS Sport on order, HRE P40 (19x9, et50, Tinted Clear)
    Other Mods: Winter/Track Wheels: Borbet LV5 (18x8, et35, Anthracite), AWE Boost Gauge, Tinted Tails, Tinted HL Reflectors, Daytona Gray Rear Valence, OSIR Coolant Tank CF Shield
  13. 10-07-2012 02:32 PM #13
    Quote Originally Posted by Black BeauTTy View Post
    Yes, the one in Wilmington, DE. Every dealership has its share of mistakes, but it is how they deal with them that makes the difference. I will be sure to update this tomorrow.
  14. Junior Member
    Jun 28th, 2012
    Doylestown, PA
    10-07-2012 07:24 PM #14
    Put lime on the oil stain and it will lift it right off.
  15. Member LynxFX's Avatar
    May 17th, 2012
    SoCal
    2013 TT-RS; APR Stage 2, 2012 Triumph Speed Triple R
    10-07-2012 08:24 PM #15
    ♩♬ You put da lime on the oil stain...and lift it right off! ♪♫
  16. 10-07-2012 08:31 PM #16
    Quote Originally Posted by rp5311 View Post
    Never would have thought of that. I will have to give it a try. If it doesn't work I can always make lime aid
  17. Member dubbinitmk6's Avatar
    Oct 25th, 2010
    El Paso, TX
    2010 VW GTI; 2013 Audi TT-RS
    10-08-2012 01:28 PM #17
    HA! And to think I was going to buy the maintenance plan.
  18. 10-08-2012 01:38 PM #18
    Update: Car towed to dealership by Audi Roadside Assistance and I had to accompany the tow truck to the dealership. Service manager said it was a "drain plug failure". I looked at the drain plug and all of the threads were intact. They replaced the drain plug and ran the car for 10 minutes with no leaks. The "drain plug failure" was more likely a failure to tighten adequately.
    In return for 4 1/2 hours of my day off, I was given some "pig pads" to absorb the oil on the garage floor and the promise of a full detail when I come in for my next service. I've never had my car detailed by a dealership before, but I'm guessing it is performed by someone with minimal training and a heavy hand on a polisher.
  19. 10-08-2012 04:17 PM #19
    And the saga continues... two hours in the driveway and two 5-inch oil stains. So, its back to the dealership to replace the oil pan and in the meantime I will be driving some econobox from Enterprise. My daughter has gotten a Q7, a Q5, an A6 and an A4 when she has brought her A4 in for service, and that car is in my name! WTF!
  20. Junior Member RoadTTripper's Avatar
    Aug 12th, 2012
    Massachusetts
    2013 TTS Prestige. Previously 2001 TT QC, 2004 QC and 2010 QC
    10-08-2012 04:38 PM #20
    MAN! Time to find another dealer/garage! You should not be in an Enterprise car when it is thier fault for whatever is going on. The only time I have ever had other than an Audi loaner is when they are completely booked out and I can't wait for a service appointment. Something is definitely not right here.
  21. 10-08-2012 06:06 PM #21
    Quote Originally Posted by RoadTTripper View Post
    That is the difference between living in Dover and my daughter living in Houston. The dealership in Wilmington does not have any loaner cars.
  22. Junior Member
    Jun 28th, 2012
    Doylestown, PA
    10-08-2012 07:07 PM #22
    Do NOT let the dealer detail your car TRUST ME!!!!! i have a flag on mine not to even wash it being the one and only time i let them wash it they put so many swirl marks on it that it that i spent a day buffing them out.
  23. Member GaBoYnFla's Avatar
    Oct 2nd, 2005
    Florida
    2011 Audi TTS
    10-08-2012 08:28 PM #23
    The bottom of the car will be the issue not the top....have you looked under it to see if the oil is all under it blown back all the way to the back....on everything? That's what happened to my R32 when they left the DSG plug loose after a "free" recall service. Made the nicely patina'd car look like it has blown a motor or something major at one time....when it was a pampered car that looked fantastic on the topside!
    I agree-don't let them detail your car unless you can't do it.
    2011 Audi TT S
    Black on Black
  24. 10-08-2012 08:33 PM #24
    I don't believe it is the DSG plug as the majority of the oil seems to be pooling in the under body tray and leaking out from there. Extremely frustrating and hard to understand since the car was perfect before going in for routine service. I will mention the DSG plug in the hopes of avoiding replacement of the oil pan.
  25. Member GaBoYnFla's Avatar
    Oct 2nd, 2005
    Florida
    2011 Audi TTS
    10-09-2012 06:32 AM #25
    Quote Originally Posted by kjmurphy View Post
    No, I'm saying that's what they did to mine.....yours sounds like the oil drain plug was left loose.....make them clean the bottom and do the top yourself. Is there oil all under the car?
    2011 Audi TT S
    Black on Black
  26. 10-10-2012 08:03 PM #26
    No, the majority of the underside was free of oil. The dealer ended up replacing the oil pan which leads me to believe that the drain was stripped. I think I will take my business elsewhere.
