Results 1 to 30 of 30
Thread: Used to get better mileage
  1. 10-06-2012 08:12 PM #1
    2003 Jetta TDI with 204k+ miles and recently the mileage has decreased (last 10 fill ups). 5 years ago, I was averaging a consistent 46.2 MPG all the time and now I rarely hit 40MPG anymore. What made me write in is that I just put 600 miles on the car, all highway which normally results in the best mileage I see. Tonight it averaged out to 38.4. Is this just age?
    In case it's not age, here's what I've looked at hoping there's some maintenance I've missed
    1) The intake is not all coked up with carbon
    2) The air filter was just replaced
    3) The MAF was out of spec last year and causing the car to go into limp mode. I replaced the MAF last year and recently found it's still within specs
    4) Tires are properly inflated
    5) I switched diesel stations in case there is a difference in fuel now from a few years ago. I've seen no change in mileage.
    6) No engine codes or engine light
    7) The timing is within specs
    The car can breathe and the fuel was eliminated as a factor, what else could it be? aging injectors?
  2. Member Rockerchick's Avatar
    May 10th, 2005
    Cary, NC
    '03 BMP 20th GTI, '84 TD Jetta
    10-06-2012 08:25 PM #2
    What transmission? How old is your fuel filter?
    Quote Originally Posted by TM87 View Post
    VW-making mechanics out of owners since 1957.
    The project - '84 Jetta 1.6TD, 186k+, fully rebuilt, Giles IP and injectors, 2.5" custom exhaust, 51mpg
    Hers - '03 BMP 20thAE GTI, 125k, all stock...for now
    His - '01 Jetta TDI, 126k. Now has 3 pedals, as it should!
  3. 10-06-2012 10:45 PM #3
    Manual transmission, fuel filter was changed about 15k ago.
  4. Member
    Mar 31st, 2008
    PNW - Oregon
    10-07-2012 01:38 PM #4
    Quote Originally Posted by hovak View Post
    might be time to do it again..
  5. 10-07-2012 02:02 PM #5
    Im new to diesel but what about some injector cleaner? I would think that would be the cheapest route. Is something like that be available for diesel?
  6. 10-07-2012 03:20 PM #6
    I'll do the fuel filter this week, I hadn't thought that would be much of an issue, but I'll give it a shot
  7. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    1999.5 Jetta TDI 5spd, MODDED
    10-09-2012 11:31 AM #7
    Is it original turbo? Original injectors? how many miles on injectors/turbo? The original 204k??
  8. 10-09-2012 08:10 PM #8
    Everything is original, turbo, injectors, etc. The only things I've had to change in 204k are the glow plugs, a few MAFs and an alternator (obviously oil, tires, fuel filter, air filters, etc).
    The car runs like a champ, just the MPG isn't what it used to be.
  9. Junior Member
    Sep 26th, 2012
    1992 Jetta ECOdiesel
    10-09-2012 11:21 PM #9
    A can of diesel purge may help or your injectors could be getting old and tired and the nozzles are worn so you are not getting as efficient of a spray pattern from them any more leading to incomplete burn and reduced fuel economy. If the springs are worn they may be popping at a lower pressure and letting more fuel through at a lower pressure which once again leads to an incomplete burn and reduced fuel economy.
    Here is a link with more info on the nozzles and there is a link to a video showing how to do a purge.
    http://www.myturbodiesel.com/1000q/m...nozzle-FAQ.htm
  10. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    10-10-2012 08:59 AM #10
    I bet your injectors are just worn. Do you run diesel additive like diesel kleen to keep things clean/boost cetane? My mileage was going down the ****ter but went up when I swapped in better nozzles (old ones had 160k something like that...), and got even better when I upgraded turbo.
  11. 10-10-2012 08:09 PM #11
    I've looked at upgrading my injectors in the past, but decided to go with a chip a few summers ago. The injectors are still stock and I've never used any additives. I would be interested in replacing the injectors but I would probably go with just stock at this point to return mileage to the old girl.
    Last I remember kermatdi.com had good injectors, do you guys have any suggestions on brands? I'm not super interested in spending a bunch of money on a 9+ year old car with 200k+ miles.
    If changing the fuel filter this weekend doesn't make a difference, I'll strongly consider a new set of injectors
    Jul 14th, 2011
    outside philadelphia
    '86 mk2 D/ '86 mk2 D '98 TDI
    10-10-2012 10:19 PM #12
    new injectors; make sure you loosen and tighten towards head, so wrench will be in opposite directions, towards trans when loosening and toward pulleys when tightening.
    (w/new injectors)run a can or 2 of lubro-moly straight, make sure you use additive when fueling up.
    run the run off return line back into can when flushing with lubro moly.
    Type I's
    the "little" D
    also 962 -0 to 60 in 4 years-
    why??more than 1 wire to shut her off?? a blasphemy!
  13. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    10-11-2012 08:26 AM #13
    Bigger injectors will get you better mileage anyways, so why not...
  14. Member
    Mar 31st, 2008
    PNW - Oregon
    10-11-2012 05:11 PM #14
    Quote Originally Posted by 85_305 View Post
    not exactly..
    the smaller nozzle will atomize fuel better, leading to a more efficient burn, and more power/economy..
    the smaller nozzle is just no good for performance, because of the limited fuel flow..
    but if you are staying stock, then it doesnt matter anyways..
    simply changing to bigger injectors will not give you more power or mileage.. you need to have the engine re-tuned before you can see the benefits of either..
  15. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    10-12-2012 09:00 AM #15
    Larger nozzles = more fuel in a shorter window which= more power/mpg.
    Yes it will need a retune.
  16. Member elrich_d's Avatar
    Aug 6th, 2008
    Pickering, Ontario
    2003 Jetta TDI GLS
    10-15-2012 12:06 PM #16
    Get dlc 1019 injector and nozzle setup. You won't need a new tune for them. I put them on my '03 and it gives a nice bump in power and fuel efficiency stays the same
  17. 10-15-2012 08:18 PM #17
    I replaced the fuel filter yesterday in hopes that would be the cause. Always best to start with the cheapest quickest fix
    Where can I get dlc 1019 injector and nozzle setup? Are they the same size as stock?
  18. Member elrich_d's Avatar
    Aug 6th, 2008
    Pickering, Ontario
    2003 Jetta TDI GLS
    10-15-2012 08:51 PM #18
    got mine from dbw but my experience with them wasn't exactly pleasant after he got my money. Its not something to get into so me personally would say not to go there. Kermatdi also offers them. I believe the nozzle holes are bigger than stock.
  19. Member
    Mar 31st, 2008
    PNW - Oregon
    10-21-2012 01:43 PM #19
    just get new nozzles for your injectors..
    search google or vortex for "injector nozzles"
  20. Member
    Jan 10th, 2003
    Barrie,On.
    '05 Jetta TDI Wagon.
    10-21-2012 02:25 PM #20
    Quote Originally Posted by Glegor View Post
    not exactly..
    Bigger nozzles absolutely increase mileage and power even with stock tuning.. The issue with the stock .184 nozzles in the manual transmission cars is that they are still injecting fuel near the end of the timing window. This doesn't help economy... With bigger nozzles (say .205's) you'll have all your fuel injected well before the window closes.. With just a nozzle upgrade, a manual tranny ALH (Stock) will see a 5% increase in mileage, 10-15hp and 30-40ftlbs of torque..
    No need to re-tune in order to see the gains a set of nozzles will give you.
    The OP should look into a set of Sprint or PP520's.. Great upgrade for a stock ALH.
  21. 11-01-2012 03:20 PM #21
    I changed my fuel filter and I'm finally writing back in after I've run a full tank of diesel through the car. The mileage is still sitting in the high 30s. As you can guess, I'm disappointed.
    If the next best option is to replace the nozzles, I'll try that to get the mileage back. I wandered around kermatdi to find stock ALH nozzles. I already have a chip in the car so I think I'll keep the nozzles stock so I don't have to get my ECU tuned. About the cheapest option I found is $335 going with their sprint 520 nozzles (older model) vs $425 with the new DLC nozzles. Everything I read, save a few articles, says just send the nozzles out for replacement and testing from a place like kermaTdi since I don't have the equipment to perform a "pop" test, etc.
    My only concern is could something else be causing this mileage decrease? Perhaps the turbo?
  22. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    11-01-2012 03:25 PM #22
    Your a fool if you spend the money on stock nozzles. and your a fool if you buy your average nozzle from DBW. He charges a TON.
    go to IDparts, grab some .216 nozzles, and have them shipped for 299$.
    Bad turbo COULD hit mileage, but only if its a pile of **** or its just really blown. Have you been running additive like DK in it?
  23. 11-01-2012 04:48 PM #23
    1) Who is DBW?
    2) I thought KermaTDI nozzles are an upgrade from stock? Are the sprint 520 nozzles junk?
    3) $299 as you suggest is only $36 difference from sending my injectors to KermaTDI, having them replace the current nozzles with Sprint 520s, test them and send them back. I thought testing was important, no?
    I've never run an additive in the car. Last I knew it was never required or even suggested.
  24. Member
    Jan 10th, 2003
    Barrie,On.
    11-01-2012 05:15 PM #24
    1) Who is DBW?
    If your injector bodies have a lot of miles on them, getting them balanced with your new nozzles is a good idea (Seatman is going to scream tears of joy to hear me say this, lol)..
    Sprint 520's are great nozzles for an otherwise stock car. PP520's would be another good choice.
    Don't worry about your turbo, I don't know why that was even brought up.
  25. 11-01-2012 06:57 PM #25
    Quote Originally Posted by MXTHOR3 View Post
    205k on original nozzles and injector bodies.
  26. Member
    Jan 10th, 2003
    Barrie,On.
    11-01-2012 07:19 PM #26
    That's not much at all to be honest.. I'd probably install the nozzle on the bodies, check group 13 and see how the numbers line up.. I've installed dozens of nozzles without a pop/calibration test and have never had an issue. If the nozzle is dead, it's dead out of the box. Nothing during the install changes that.
  27. Member bengone1's Avatar
    Jun 17th, 2003
    Newport News VA
    2001 allroad 6sp, 98 GTi TDi, Caddy TDi to be
    11-01-2012 08:58 PM #27
    How about intake manifold clogging?
    Malone tuning services available- Contact Ben at MaloneTuningVA@gmail.com
    http://malonetuning.com
    MK4, B5, B5.5 remote window control recoding available and VCDS MK5/6. SKC retrieval, Cluster matching, IMMO programming/delete.
  28. Member
    Jan 10th, 2003
    Barrie,On.
    11-01-2012 10:01 PM #28
    Quote Originally Posted by bengone1 View Post
    #1 on the OP's list that he's checked.
  29. Member bengone1's Avatar
    Jun 17th, 2003
    Newport News VA
    11-01-2012 10:05 PM #29
    Ha! missed it completely.
  30. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    11-02-2012 08:56 AM #30
    1) Who is DBW?
    DBW= Drive Bi Wire. Good guy, very smart. Also terribly pricey. Sprint 520 are great nozzles... I'm saying your a fool if you PURCHASE oem nozzles when aftermarket could be had for probably less, and will give you more benefits.
    For our rotary pump TDI's, I 1,000% recommend an additive like diesel kleen. I notice 2-3mpg improvement when using it. Not to mention, the reassurance of my fuel not gelling in winter time and not worrying about trashing my pump and injectors from lack of lubricity.
    See below.... THATS why "turbo" was brought up in this.
    This right here
    Not bad. Read below.
    This. If anything, it's only a few bucks for these injectors to be balanced... but only very few shops can actually shim them or adjust them. Specifically, Bosch shops.
