Hi guys, please don't flame me for not using the search button. I tried but came up with nothing. I just bought a pair of 8mm H&R Dr spacers for my aristo stock wheels. However dumb enough, I forgot to purchase the extended bolts. Can someone here using the same setup kind enough to share the bolt size so that I can buy here locally? My spacers are now stuck in the garage, really appreciate if some user here can help. Thanks for all your help in advance.
Stock bolt length is 28mm, so simply add the width of whatever spacer you use. In your case, you're looking for M14x1.5 36mm length. Also be sure to get ball-seat bolts (as opposed to cone) for the OEM wheels.
Thanks for your reply. I found some info on another forum, the bolt size is m14 x1.5 x35 mm in length. I think the 1mm length in difference won't matter? Or would it?
