VWVortex.com - Intake Tube 2.0 16V Megasuirt w/Passt TB
    Results 1 to 13 of 13
    Thread: Intake Tube 2.0 16V Megasuirt w/Passt TB
    1. Member 16ValveInside's Avatar
      Nov 20th, 2004
      South Carolina
      91 GTI 16V Current Project. 91 GTI 8V. 91 GTI 16V (totaled). 91 Jetta GL. 1967 & 1955 Cal-Look/48IDA
      10-07-2012 09:59 AM #1
      What did you use for a Intake Tube.
      I would rather go with a black plastic one, I'll be using a Passat t/body and the OE rubber elbow, and then out to a filter, but I'm looking and can't find anything.
      91 GTI 16V Project - All Motor - My Build Thread - http://forums.vwvortex.com/showthrea...ssembly-Thread
      Aug 8th, 2004
      Rockaway,NJ
      94 golf
      10-07-2012 03:07 PM #2
      you can fit a coupler over the oval throttle body. try one of the thinner style silicone couplers.
    3. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      10-07-2012 03:19 PM #3
      I kept all the stock pieces and gutted the airbox of the metering plate and stuff and even opened up the hole the plate sat in.
    4. Member 16ValveInside's Avatar
      Nov 20th, 2004
      South Carolina
      10-07-2012 04:14 PM #4
      Quote Originally Posted by bonesaw View Post
      Thanks, good to know, now where can I find a Intake tube with no "bling"?
    5. Banned ellocolindo's Avatar
      Jan 14th, 2010
      10-07-2012 10:08 PM #5
      if interested i have passat and mk2 16v intak epipes. oem plastic. or also a cabriolet 85 8v intake pipe.
    6. Member 16ValveInside's Avatar
      Nov 20th, 2004
      South Carolina
      10-13-2012 10:20 AM #6
      anyone have any pics of what they used on a 16V engine
    7. Junior Member
      Dec 8th, 2007
      Czech Republic (Europe)
      Mk1 GTI '78 16v ITB
      10-14-2012 03:54 AM #7
      I do..
    8. Member 16ValveInside's Avatar
      Nov 20th, 2004
      South Carolina
      10-14-2012 05:32 PM #8
      Quote Originally Posted by lister@vw-club.cz View Post
      I do..
      Thanks, looking good, did you fab that one yourself? I read that an intake tube for a 92 Civic fits.
    9. Junior Member
      Dec 8th, 2007
      Mk1 GTI '78 16v ITB
      10-15-2012 01:46 AM #9
      no, it's an aftermarket replacement for OEM plastic tube, some people believe that bigger diameter makes more power
    10. Member 16ValveInside's Avatar
      Nov 20th, 2004
      South Carolina
      10-15-2012 10:31 AM #10
      might be one of the ABD big bore tubes. I'm looking for something a little longer.
      I'll probably order one of the 92 honda civic short ram intake tubes with K&N filter off ebay
    11. Member 16ValveInside's Avatar
      Nov 20th, 2004
      South Carolina
      08-24-2014 10:48 AM #11
      I bought one of the AirAid U build it Universal Intake kits 3" diameter without the filter and clamps, etc. just the black plastic tube.
      Its shaped like a big U and all the different bends and straight pieces are all made together, just cut between the lines and use the pieces you need.
      I'll post a pic when I finish.
    12. Member DocWalt's Avatar
      Sep 6th, 2012
      Royersford, PA
      1992 GTI
      09-08-2014 03:08 PM #12
      ABD big bore intake tube with a Digi airbox upper modded with a plastic digi cone filter adapter in place of the MAF... I forget the size of PVC pipe we used to fit, but the mod wasn't too terrible. I even had my brother do the work for me
      If that didn't work out I'd have done exactly what ps2375 did, the CIS stuff flows plenty of air with the flapper and arm removed. His porting work on the housing looks like a really nice improvement too.
      R135
      - 24
    13. Member 16ValveInside's Avatar
      Nov 20th, 2004
      South Carolina
      09-13-2014 05:36 PM #13
      right out of the box the u-build-it intake tube - I ordered the 3" tube
      just cut between the ribs with a a PVC /plastic saw and smooth down the edges with a PVC/plastic file
      bought some couplers and still playing with the pieces trying different ways to route the intake
      or
      what do you think
