Results 1 to 24 of 24
Thread: Washer/dryer advice
    Jan 29th, 2009
    Valdosta, Ga
    '01 S2000, '05 MDX, '06 Accord EX-L
    10-07-2012 10:00 AM #1
    I was listening to Carolla's podcast the other day and he said that they make a device that:
    a) disconnects power from both of them automatically when they're not in use. Dunno if you guys are aware but dryers have a tendency to spontaneously self-combust and burn down your house, even when they're not in use; and
    b) disconnects the water lines from your washing machine when it's turned off. I hadn't really thought about it, but the hoses eventually get old and split open and flood your house.
    I'm not necessarily paranoid but I'm interested in something like that.
    Anyone?
    You think I ain't worth a dollar, but I feel like a millionaire.
  2. Member barry2952's Avatar
    Jun 13th, 2007
    Farmington Hills, MI
    10-07-2012 10:41 AM #2
    Quote Originally Posted by rice is burning View Post
    Anyone?
    (a) is purely a maintenance and proper installation issue. If you have flex duct, get rid of it. It's the built up dust and lint that catches fire.
    (b) is simply cured by installing stainless braided hoses.
    (c) make sure your outlet is not clogged with a bird's nest.
    Garmin Is My Pilot.
  3. Member GeoffD's Avatar
    Aug 13th, 2001
    10-07-2012 11:24 AM #3
    My stainless braided hot water hose failed when it was 8 months old. I was living in my other house at the time. The insurance check to replace hardwood floors (also 8 months old) and sheet rock/insulation was $8,000.
    I now have a washing machine water shutoff and use it religiously. I also added a whole house shutoff that kills water to everything but my boiler and I use that religiously when I'm gone for more than a few days.
    ...and in the spirit of "while it's opened up", those repairs uncovered a rotted sill. ...and the whole front of the house was re-framed from the inside-out. ...and the electrical in those opened up walls was rewired. It delayed my bathroom remodel project by a year. The new framing and insulation make a big difference with neighborhood noise. It used to be that a neighbor mowing their lawn sounded like the mower was in my living room.
  4. Member barry2952's Avatar
    Jun 13th, 2007
    10-07-2012 11:27 AM #4
    Quote Originally Posted by GeoffD View Post
    That's pretty rare.
    Garmin Is My Pilot.
  5. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-07-2012 02:06 PM #5
    Not only is it 'extremely rare'.. I'd have to see a pic to believe it.
    More likely the seal at the end of the hose was damaged or had debris upon install than the physical hose itself fail. The entire purpose of the braid is to prohibit the hose from being able to expand and burst.
    Washers can leak for several reasons. 99% of the time, they will only leak while in the process of being ran. The other time, the fill valves that open and close to regulate the fill can fail. Normally they leak slowly when bad (like a leaky kitchen faucet) and just fill the machine when they shouldn't. People will come to the machine the next day and it will have water in the tub from overnight. On rare occasion, the leak will be fast enough to fill the machine and overflow on the floor.
    They sell hoses with self closing pressure valves inside. Junk. They are more trouble than they are worth. They close when they are not supposed to and people think the machine is broken.
    They also sell fancy electronic solenoid valves that install at the wall and go to a 'sensor' on the floor that shuts off the flow if it gets wet. Waste of money. As suggested, just get SS lines and call it a day. If you are paranoid, manually shut the valves yourself when not in use.
    Dryers do NOT spontaneously 'self-combust'. As Larry point out, dryer fires are caused by venting issues.. obstruction due to lack of maint, animals, kinked or crushed venting between machine and wall, etc. If there were no buildup of fuzz or birds nest in places it shouldn't be.. you can leave a dryer on all day long and not start a fire. The physical components that allow it to heat will eventually fail and cease to function.. but no fire will occur.
    -Josh
    Jan 29th, 2009
    Valdosta, Ga
    10-07-2012 02:09 PM #6
    What are you using? I maintain my house but I also use $10/qt oil in my 11 year old Honda. Is it a waste of time? Maybe. Is it a waste of money? Maybe.
    Things tend to break. Mine probably won't but the risk/reward factor leans towards being a little pro-active.
  7. 10-07-2012 02:28 PM #7
    my (12 year old) washer just died with the tub full of water....how do I drain the water out?
  8. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-07-2012 02:44 PM #8
    You need to be more specific.
    Top load? Front load? Brand?
    -Josh
  9. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-07-2012 02:45 PM #9
    Just for fun, I am going to take a shot in the dark.
    I'm going to guess a Whirlpool built top load with a mechanical dial.
    I'm going to guess the lid switch is broken- on the right hand side when you open the lid.
    -Josh
  10. 10-07-2012 02:49 PM #10
    Admiral (Maytag); top load; mechanical dial.
    had been making a loud ratcheting sound for a couple of weeks.
    doing same today when I heard a loud bang. faint electrical smell.
  11. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-07-2012 02:54 PM #11
    Same answer- check lid switch.
    Most of those basic style of washers use a simple open/close contact. If you have no small children and no intention of sticking your arm into the unit whilst on the spin cycle; bypass the switch.
    -Josh
  12. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-07-2012 02:57 PM #12
    No fair editing your post with new info.
    Skip the lid switch. You ignored a mechanical cry for help and let something turn into something worse. Never a good idea to run things when they make funny noises. There is generally a reason.
    If it truly is an electrical smell instead of a rubber belt slipping smell.. then it is coming from your motor.
    ShopVac out the water. Buy new machine.
    -Josh
  13. 10-07-2012 03:01 PM #13
    thanks
  14. Member barry2952's Avatar
    Jun 13th, 2007
    10-07-2012 03:17 PM #14
    Quote Originally Posted by PowerDubs View Post
    I may use that, thanks.
    Garmin Is My Pilot.
  15. Member GeoffD's Avatar
    Aug 13th, 2001
    10-07-2012 03:46 PM #15
    It failed where the hose meets the connector at the faucet.
  16. 10-07-2012 09:17 PM #16
    Quote Originally Posted by Chameleon2 View Post
    Is it a direct drive? If so, the drive coupler probably failed. Probably need something like this: http://www.bafiltersupply.com/Genuin...A-_p_3843.html
  17. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-07-2012 09:33 PM #17
    No need for a whirlpool coupler on a 12 y/o Admiral/Maytag.
    Whirlpool didn't purchase Maytag until 6-7 years ago.
    And a broken motor coupler causes a disconnect from the transmission. The unit would still fill and drain.. just not spin / agitate.
    - Josh
    -Josh
  18. Member rbloedow's Avatar
    Aug 14th, 2003
    Panama City, FL
    2012 Chevy Volt
    10-07-2012 10:28 PM #18
    That's pretty rare.
    Not really - even braided lines should be replaced every few years. It recently happened to a friend of mine.....
  19. 10-07-2012 11:27 PM #19
    I have some apartments and use the manual shut off valves in all of them with stainless braided hoses. No problems.
    My gf's upstairs neighbour last year had regular hoses that blew out and flooded her place. It was a mess. Insurance covered it but it was still a hassle. Got my gf some stainless lines right away.
  20. Member
    Nov 10th, 2002
    NJ
    04 W8 6spd Wagon
    10-08-2012 07:01 PM #20
    I just saw this on This Old House the other day:
    http://www.timeoutbykeeney.com/
    I might be getting one of those.
    Originally Posted by rconn14:
    The fact that someone invented a system that saves you the struggle of turning your head to check your blind spot, yet there is no dash-light that says "get your ass out of the left lane you cell phone wielding ****"
  21. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-08-2012 08:17 PM #21
    WTF for?
    Turn the water on when you put the clothes in, turn it off when the load is done.
    You really need a timed device to do this for you?
    -Josh
  22. Member
    Jan 29th, 2009
    Valdosta, Ga
    10-26-2012 10:43 PM #22
    Ummm they do catch on fire, occasionally. Normally, no.
    Also Dodge Ram trucks do not melt their wiring harnesses and catch on fire. I watched it happen, and I tried to fight it with a fire extinguisher as I called 911 on my phone. It burned to the ground.
    I specifically heard a dude with years of construction experience say that there is an easy way to prevent potential disaster with a couple of devices. Also he wasn't trying to sell me anything.
    I could go bang 50 girls and there's a large probability that I wouldn't get HIV. Odds are I wouldn't take my chances.
    Later, ricey
  23. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    10-26-2012 10:49 PM #23
    Believe what you want. I do this for a living.
    - Josh
    -Josh
  24. Member barry2952's Avatar
    Jun 13th, 2007
    10-27-2012 08:22 AM #24
    People believe stupid ****. What ae you going to do?
    They make stupid analogies to try to make their point, too.
    Garmin Is My Pilot.
