Results 1 to 5 of 5
Thread: is there anyone in ma that can do a immblizer delete
  1. Junior Member
    Mar 28th, 2012
    mass
    10-07-2012 10:22 AM #1
    like the title says. My car is immoble and the car and key light flashes when i try to start it. The car starts but dies Im in gardner if anyone is local
  2. Junior Member
    Jun 9th, 2009
    Walpole, MA
    2005 Golf GLS 2.0
    10-09-2012 10:06 AM #2
    What year is your car? That sounds like the key may not be coded to the car-- anyone with VAG-Com can fix it if that is the problem.
    Have you swapped the instrument cluster or ECU?
  3. Senior Member MFZERO's Avatar
    Mar 13th, 2002
    Haverhill, Ma.
    2011 Kink Gap Xl, 2000 Haro Blammo,'08 Gti
    10-09-2012 11:26 AM #3
    If you haven't changed anything on the car (instrument cluster, key, ecu) try a capacitive discharge (disconnect both battery leads and touch them together for 15 seconds).
    Try it at your own risk though.
  4. Member CorradoG602's Avatar
    Jan 22nd, 2007
    Framingham, Ma
    '07 chevy crew cab, Bobbed '81 XS650
    10-09-2012 01:50 PM #4
    you can't delete the immobilizer.
    NEK Bobbed XS650 '07 Chevy Crew Cab
  5. Member Local603's Avatar
    Feb 11th, 2003
    03079 Live Free or Die
    10' Crew Cab Silverado - 05' Harley with a hard on - 04' bagged bagger - 99' 400ex - 84' Chevy C10
    10-09-2012 04:13 PM #5
    I bet this is mk4 content.
    Super easy to delete immo... Just take your whole harness and ECU out, swap with a early passat harness and ECU. Done. Stand back, have a wine cooler... Because now you are awesome!
    Vag-Com services 1990 through current model year. PM me with your needs.
    Mild to Wild Motorcycle Work: www.facebook.com/Local603Chops
    NEK
    ed
