Results 1 to 9 of 9
Thread: Jetta glx vr6 2001
  1. Junior Member JETTAFRESHPR's Avatar
    Apr 6th, 2011
    PR
    2001/JETTA/VR6
    10-07-2012 12:21 PM #1
    Hey everyone i need some info about how many quarters of oil i need to fill up my jetta glx vr6 2001 transmission and what good name brand to buy if anyone could help thanks
  2. Member MK4_NINJA's Avatar
    May 2nd, 2011
    Nebraska
    2001 GTI VR6 (RAVE GRN)
    10-07-2012 12:33 PM #2
    Google would probably help you a lot easier and faster, but I use close to 6 quarts and I use MOBIL 1 0w-40 Full Synthetic.
    VRalliance #31
  3. Junior Member JETTAFRESHPR's Avatar
    Apr 6th, 2011
    PR
    2001/JETTA/VR6
    10-07-2012 12:36 PM #3
    And how many for transmission fluid ?
  4. Member MK4_NINJA's Avatar
    May 2nd, 2011
    Nebraska
    10-07-2012 12:43 PM #4
    2 Qts
    VRalliance #31
  5. Junior Member JETTAFRESHPR's Avatar
    Apr 6th, 2011
    PR
    2001/JETTA/VR6
    10-07-2012 12:51 PM #5
    Thanks for your hel bro
  6. Junior Member JETTAFRESHPR's Avatar
    Apr 6th, 2011
    PR
    2001/JETTA/VR6
    10-07-2012 12:56 PM #6
    Forgot one more ? Should i buy any name brand for the transmission fluid
    or a specific one any recommendations in what brand should i buy ?
  7. Member RDIRTYTOO's Avatar
    Oct 4th, 2007
    syracuse, ny
    98 glx,01 jetta glx,01 wolfsburg,00 gls vr6,11 wrangler sahara, 04 bmp turbo R sold,97 glx
    10-07-2012 09:26 PM #7
    mobil 1 0w40 full synthetic, takes 5.5 qts
    Jul 18th, 2010
    Pottstown, Pennsylvania
    PG 01 Wolfsburg (R.I.P), Rave Green GTI
    10-07-2012 09:47 PM #8
    try to stick with OEM fluids when changing them (coolant, trans fluid ect.). i believe the oem transmission fluid for a 5 speed is G 070 fluid..
  9. Member RedWabbitVR's Avatar
    Feb 28th, 2006
    Lansdale
    84 Rabbit Convertible VR6, 81 Rabbit Hatch, 81 Rabbit Diesel Caddy, 00 Jetta VR6, 01 Jetta 2.0
    10-08-2012 09:18 PM #9
    Quote Originally Posted by JMKDUB View Post
    sure if you like spending too much money. $20 per liter of autotrans fluid and I needed 6 no f'n thanks.
    I use gm syncromesh with all my manual transmissions, I had a slight 2nd gear grind with a replacement I had with my vr6, it got rid of it. I've used it with alot of success with other manuals as well.
    VRSociety #301
