VWVortex.com - Upshifting with Manual Transmission: Which theory is correct?
    The Car Lounge
    Page 2 of 2 FirstFirst 12
    Results 26 to 50 of 50
    Thread: Upshifting with Manual Transmission: Which theory is correct?
    1. Member admiralbabar's Avatar
      Jan 13th, 2011
      central texas =(
      951, 944, coupe quattro, mk4
      10-07-2012 03:56 PM #26
      ^^^ The .gif really seals the deal on that one
      2nd option has never given me any trouble and I've always gotten loooooong life out of my clutches. Some people are better than others at it, mostly.
      ...and those who were seen dancing were thought to be insane by those who could not hear the music...
      Life is short....if you can, you must
    2. Member yurikaze's Avatar
      Jul 7th, 2006
      Rancho Palos Verdes, CA
      '77 S30, '85 AE86, '15 CR-Z
      10-07-2012 04:03 PM #27
      This sounds like the ministry of silly shifting.
    3. Member MangoBurnout's Avatar
      Jun 24th, 2011
      Toronto, Canada
      E36 BMW
      10-07-2012 04:06 PM #28
      those 2 are the exact same thing. one is faster.
      option #3. get an auto.
    4. Member Activ8's Avatar
      Aug 25th, 2011
      Ann Arbor, MI
      2006 Lancer Evo 9, 2013 FR-S
      10-07-2012 04:17 PM #29
      Quote Originally Posted by USMC_Artmayer View Post
      1. gas to floor
      2. without lifting right foot stomp clutch
      3. bang gear
      4. release clutch
      power shift it son
      Impossible on a Carrera GT .... it's a bit counter-intuitive, but you've got to slam the clutch and lift off as fast as possible instead of slowly and no gas until full engagement felt, then slam the power pedal to the floor .....
      Feb 3rd, 2006
      North Las Vegas
      2014 Honda Civic LX sedan 5M
      10-07-2012 04:23 PM #30
      Quote Originally Posted by WhitePoloCT View Post
      You are over-thinking this. You should do whatever is smoothest. For me, it's closest to #2.
      Quote Originally Posted by 03GTI4Me View Post
      It would seem to me that beginners start out on the 1st option with the goal of becoming more experienced and getting to the second option.
      Both of the above.
      Quote Originally Posted by Broduski View Post
      TCL would suggest a Bi-Turbo to a single mother of 4 just for sh*t's and giggles.
      Quote Originally Posted by Metallitubby View Post
      Ford will finance anyone.
      If the torque number is higher than the credit score, there will be injuries.
      Quote Originally Posted by Sold Over Sticker View Post
      If you need me, I'll be chirping 3rd in my Chevy.
    6. Member dopaz's Avatar
      Jun 17th, 2002
      Mechanicsburg, PA
      [Current:] 03 Ram [Past:] 84 Rabbit, 85 Quantum, 87 Jetta, 97 Jetta, 96 Passat
      10-07-2012 05:24 PM #31
      1. gas to floor
      3. bang gear
      4. release clutch
      power shift it son
      So much fun! I wonder what my second gear synchro looks like though...
    7. Member Live-Wire's Avatar
      Jun 9th, 2005
      Georgetown Ontario
      2015 Mazda CX-5 GT, 2012 Dodge Journey 3.6 R/T AWD
      10-07-2012 06:13 PM #32
      Whatever is the smoothest and causes least amount of slip on the clutch (comes hand in hand with smoothness... so it's a win win) is the best. Ideally you need to use the throttle to match engine rpm with new road speed. Using a bit of throttle is not going to burn up the clutch - but having a massive difference in engine to road speed will (in either direction... over revving, or under revving).
      It's best when the shifts are almost imperceptible, and the rpm looks correct; it should fall towards where it needs to be in the next gear, then you will 'catch' it by applying just enough throttle to prevent it dropping furthur. Of course you can only apply sufficient throttle to really accelerate the car when the clutch pedal has been released.
      Operating any machinery the key to longevity is smoothness, smoothness, smoothness.
    8. Member B3sat16v's Avatar
      Jan 23rd, 2002
      Around the world
      MH-60R
      10-07-2012 06:21 PM #33
      It is situational dependent.
      Sometimes I do not use the clutch other than first gear.
      FLY NAVY
    9. Member compy222's Avatar
      Apr 7th, 2005
      Pothole, Midwest
      Honda Fanboy Collection
      10-07-2012 06:22 PM #34
      1 if the box is cold. 2 normally or driving hard.
      Quote Originally Posted by capsaicin View Post
      AP1 S2000? I can not in good conscience talk you out of that. May your slip angle be great and your bed not be the couch!
      Jul 22nd, 2011
      pgh pa
      10-07-2012 06:30 PM #35
      let off gas.
      load is taken off gears
      slips easily out of gear and while in between gears
      push in clutch
      select next gear
      let out clutch
      hit gas.
      i find myself doing this fairly often even though im sure its not very good for syncros.
      but it seems like i have very little to no shift shock at all doing this.
      anyone know if this method is bad for the gearbox or not??
      ps.
      i do this only while driving normally with low2500-3000rpm shifts.
      Jun 13th, 2004
      Germany
      '05 S2000, '02 Polo
      10-07-2012 06:37 PM #36
      In the Rabbit (rev hang, terribly spongey mounts) option 1 is the smoothest.
      In the CRX option 2 is the smoothest.
    12. 10-07-2012 06:43 PM #37
      Assuming you're upshift rev-matching, I don't get why people think option 2 would be less wear on the clutch.
      With 2 you're slipping the clutch with each upshift, which does it make it smoother (less shock from just releasing the clutch), but means more wear, no?
      Driving a beater Lexus to save up for a fun car, driving a beater Lexus to save up for a fun car, driving a beater Lex.....
    13. Member
      Dec 22nd, 2011
      Lancaster, PA
      MK4 JTI 1.8t (sold), 1986 GSX-R 1100, MK3 Jetta 2.0t (sold), W210 E430
      10-07-2012 06:51 PM #38
      I go with number 2 in the b6 a4. Also is resting your hand on the shifter bad for the synchros? I read somewhere that it is bad.
    14. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      '14 ATS 2.0T 6MT, '16 Camaro 2SS 8AT, '14 Moto Guzzi V7
      10-07-2012 06:53 PM #39
      2
    15. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      10-07-2012 06:53 PM #40
      Quote Originally Posted by CAH8 View Post
      Bad for the TOB.
    16. Member joedubs's Avatar
      Feb 2nd, 2004
      07 wrx wagon, 99 a4 avant BT
      10-07-2012 07:05 PM #41
      Leaving your hand on the shifter has absolutely nothing to do with the throw out bearing (if that's what you meant by TOB)...
      If you do method 1 too slow (which I can only imagine you would be, if you're actually thinking about it) chances are the rpms drop way too much between shifts. When you let the clutch back out it'll slip all the way back to where they should be. Furthermore as someone else said, the engine braking will lead to a pretty sloppy shift.
      In normal driving I only use the clutch when re-engaging the gear. If you dont load up the trans too much (no acceleration or deceleration) it pulls right out of gear without clutching in.
    17. Member 71DubBugBug's Avatar
      Dec 3rd, 2006
      Chicago
      91 Audi D11 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
      10-07-2012 07:41 PM #42
      I have heard this before as well, i think it depends on what you call resting, if your elbow is on the center arm rest i think its ok, if the weight of your entire arm, then no
    18. Member delrio's Avatar
      Feb 18th, 2012
      w202
      10-07-2012 08:16 PM #43
      Quote Originally Posted by dopaz View Post
      Broke mine a long time ago
      I'm Brandon
      Quote Originally Posted by Wanganrunner View Post
      I would drag my d*ck through a mile of broken glass to hear her fart through a walkie talkie.
      Quote Originally Posted by Lwize View Post
      I'll have my fun while I can. Automatics aren't so bad. Neither is socialism...
    19. 10-07-2012 09:02 PM #44
      Quote Originally Posted by delrio View Post
      On your ti?
      I think my 318ti's 2nd gear synchro is going out. Sometimes when I shift to 2nd and it feels like it engaged, but its actually not. Then, when I try to push the gear into 2nd completely, it grinds.
    20. Member delrio's Avatar
      Feb 18th, 2012
      w202
      10-07-2012 09:07 PM #45
      Quote Originally Posted by mac dre View Post
      On your ti?
      Actually on my jetta
      ti trans can take a beating for the most part and not run into problems at least from my experience and what I read about others.
      I'm Brandon
    21. Member Jimmy Russells's Avatar
      Feb 4th, 2007
      Vancouver
      2011 GTI 2dr 6M, 2014 JKU
      10-08-2012 01:42 AM #46
      2
      1 just seems wrong
      The OG Russells is back!
      Quote Originally Posted by Sump View Post
      I'm sure a lot of these guys went home after the carwash and played a little hans solo.
    22. Member genjy's Avatar
      Aug 7th, 2005
      Glendora, CA
      Volvo C30 6spd / Mazda5 5spd / '16 Subaru STI 6spd
      10-08-2012 01:58 AM #47
      I think mine is closest to #2.
      #1 seems really clunky and it's just not really how it's supposed to be done.
    23. Member
      Mar 28th, 2004
      Austin TX
      10-08-2012 02:10 AM #48
      #1 in my Subaru and #2 in the bimmer. It also depends on rpm. Higher rpm shifts tend to feel like #2.
    24. Member TetsuoShima's Avatar
      Nov 30th, 2008
      Hamilton, Ontario, Canada
      1994 Honda Prelude V-TAK
      10-08-2012 02:29 AM #49
      Quote Originally Posted by Mr Miyagi View Post
      Just put it in drive.
      Just put it in H
    25. 10-08-2012 10:57 AM #50
      Not so, if you get the timing correct. Simultaneously disconnecting the clutch as you are taking load off the engine (releasing accelerator pedal) means it's not slipping on the first step. Re-engaging the clutch after the engine has come down in revs during the shift to roughly the same speed, so that there is not a major step in engine speed that the clutch has to take up, means there's absolute minimum slippage on re-engagement. Done correctly, the gear change is very smooth with next to no slippage.
      I've put 400,000 km on two different manual transmission cars and never had to change a clutch. The Jetta is going to need a clutch soon, but only because of the crappy DMF mechanism (which wears itself out regardless of what the driver does).
