Page 2 of 2 FirstFirst 1 2
Results 36 to 50 of 50
Thread: Upshifting with Manual Transmission: Which theory is correct?
    Jun 13th, 2004
    Yuba City, CA
    '05 S2000, '90 CRX
    10-07-2012 05:37 PM #36
    In the Rabbit (rev hang, terribly spongey mounts) option 1 is the smoothest.
    In the CRX option 2 is the smoothest.
  2. Member mac dre's Avatar
    Jan 20th, 2008
    St. Louis/Columbia, MO
    318ti
    10-07-2012 05:43 PM #37
    Assuming you're upshift rev-matching, I don't get why people think option 2 would be less wear on the clutch.
    With 2 you're slipping the clutch with each upshift, which does it make it smoother (less shock from just releasing the clutch), but means more wear, no?
    Quote Originally Posted by efrie View Post
    I told him the car wasn't going to win any races, to which he responded was "chill".
    Dec 22nd, 2011
    Lancaster, PA
    MK4 JTI 1.8t
    10-07-2012 05:51 PM #38
    I go with number 2 in the b6 a4. Also is resting your hand on the shifter bad for the synchros? I read somewhere that it is bad.
  4. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    B6 Variant 3.6L VR6 4Motion | E30 325e | MKVI Golf 2.5L | Versys 650
    10-07-2012 05:53 PM #39
    2
    ECSTUNING | GO APR
  5. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    10-07-2012 05:53 PM #40
    Quote Originally Posted by CAH8 View Post
    Bad for the TOB.
    ECSTUNING | GO APR
  6. Member joedubs's Avatar
    Feb 2nd, 2004
    07 wrx wagon, 99 a4 avant BT
    10-07-2012 06:05 PM #41
    Leaving your hand on the shifter has absolutely nothing to do with the throw out bearing (if that's what you meant by TOB)...
    If you do method 1 too slow (which I can only imagine you would be, if you're actually thinking about it) chances are the rpms drop way too much between shifts. When you let the clutch back out it'll slip all the way back to where they should be. Furthermore as someone else said, the engine braking will lead to a pretty sloppy shift.
    In normal driving I only use the clutch when re-engaging the gear. If you dont load up the trans too much (no acceleration or deceleration) it pulls right out of gear without clutching in.
  7. Member 71DubBugBug's Avatar
    Dec 3rd, 2006
    Chicago
    91 Audi D1 V8, 71 Super, 07 E320 Bluetec, 05.5 Jetta 2.5
    10-07-2012 06:41 PM #42
    I have heard this before as well, i think it depends on what you call resting, if your elbow is on the center arm rest i think its ok, if the weight of your entire arm, then no
  8. Member delrio's Avatar
    Feb 18th, 2012
    94 2.0/89 CRX
    10-07-2012 07:16 PM #43
    Quote Originally Posted by dopaz View Post
    So much fun! I wonder what my second gear synchro looks like though...
    Broke mine a long time ago
    I'm Brandon
    Quote Originally Posted by Wanganrunner View Post
    I would drag my d*ck through a mile of broken glass to hear her fart through a walkie talkie.
    Quote Originally Posted by Lwize View Post
    I'll have my fun while I can. Automatics aren't so bad. Neither is socialism...
  9. Member mac dre's Avatar
    Jan 20th, 2008
    318ti
    10-07-2012 08:02 PM #44
    Quote Originally Posted by delrio View Post
    On your ti?
    I think my 318ti's 2nd gear synchro is going out. Sometimes when I shift to 2nd and it feels like it engaged, but its actually not. Then, when I try to push the gear into 2nd completely, it grinds.
  10. Member delrio's Avatar
    Feb 18th, 2012
    94 2.0/89 CRX
    10-07-2012 08:07 PM #45
    Quote Originally Posted by mac dre View Post
    On your ti?
    Actually on my jetta
    ti trans can take a beating for the most part and not run into problems at least from my experience and what I read about others.
    I'm Brandon
  11. Member ThreadBomber's Avatar
    Feb 4th, 2007
    Vancouver
    2011 GTI 2dr 6M
    10-08-2012 12:42 AM #46
    2
    1 just seems wrong
    Teefy Buna
    Quote Originally Posted by Sump View Post
    I'm sure a lot of these guys went home after the carwash and played a little hans solo.
  12. Member genjy's Avatar
    Aug 7th, 2005
    Glendora, CA
    Volvo C30 T5 6sp manual / Mazda5 5sp manual
    10-08-2012 12:58 AM #47
    I think mine is closest to #2.
    #1 seems really clunky and it's just not really how it's supposed to be done.
  13. Member bombardi's Avatar
    Mar 28th, 2004
    Austin TX
    E39, GC8 RS and bicycle.
    10-08-2012 01:10 AM #48
    #1 in my Subaru and #2 in the bimmer. It also depends on rpm. Higher rpm shifts tend to feel like #2.
  14. Member TetsuoShima's Avatar
    Nov 30th, 2008
    Hamilton, Ontario, Canada
    1994 Honda Prelude V-TAK
    10-08-2012 01:29 AM #49
    Quote Originally Posted by Mr Miyagi View Post
    Just put it in drive.
    Just put it in H
  15. 10-08-2012 09:57 AM #50
    Not so, if you get the timing correct. Simultaneously disconnecting the clutch as you are taking load off the engine (releasing accelerator pedal) means it's not slipping on the first step. Re-engaging the clutch after the engine has come down in revs during the shift to roughly the same speed, so that there is not a major step in engine speed that the clutch has to take up, means there's absolute minimum slippage on re-engagement. Done correctly, the gear change is very smooth with next to no slippage.
    I've put 400,000 km on two different manual transmission cars and never had to change a clutch. The Jetta is going to need a clutch soon, but only because of the crappy DMF mechanism (which wears itself out regardless of what the driver does).
