Results 1 to 9 of 9
Thread: ABS light ON, and "No response from controller" message in vag com 409.1
  1. n00b
    Oct 7th, 2012
    98 V6 VW Passat
    10-07-2012 04:43 PM #1
    hello everyone!
    this is my first time here, could anyone please help figure out what's going on with my abs?
    when i turn the ignition on the car makes three short beeps and three long ones, also the airbag light, the abs, CEL, and the brake light are all on and solid...when i start the engine same thing for the lights, plus tachometer doesn't work, sometimes it moves when i first start the engine but it goes back down to zero immediately.
    i have the cheap ebay cable and vag com 409.1 that i am using, when the 31 pin connector is plugged to the abs module, and i try to scan abs brakes (address 03) it says no response from controller, and it tells me the same thing when i try to scan the engine(address 01). but with the abs module unplugged, the engine scans fine.
    any help would be very appreciated, thanks!!
  2. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    10-07-2012 08:51 PM #2
    It is apparently a common issue that the abs controller fails. There is a bad solder joint in it. When it fails, it will no longer respond to queries from vagcom or any other tool. Fix is to send it somewhere to get repaired or pay big bucks and replace it.
  3. Member 8V Fury's Avatar
    Jul 26th, 2003
    roseville, california
    2004 vw jetta wagon, 1990 vw jetta coupe
    10-08-2012 12:25 AM #3
    I would recommend bbk reman to get your abs control repaired or exchanged and both come with a lifetime warranty.
    Quote Originally Posted by Ron@RMAMotorsport View Post
    real deal<p>After spending two months in the mk3 forum it drove into the woods and set fire to itself.
  4. n00b
    Oct 7th, 2012
    98 V6 VW Passat
    10-08-2012 01:05 AM #4
    I tried another abs module that I got from a junkyard, and the same thing happened, when it's unplugged I can scan the engine, when I plug it I can't...does that mean the other abs module is junk too?
    Thanks!
  5. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    10-08-2012 01:45 AM #5
    Quote Originally Posted by younes424 View Post
    Thanks!
    good chance it is...
  6. n00b
    Oct 7th, 2012
    98 V6 VW Passat
    10-08-2012 10:48 AM #6
    My abs module part number is 0273004 135. Does the replacement have to match down to the last number?
  7. Member 16v po boy's Avatar
    Oct 26th, 2001
    Winston Salem NC
    02 w8 twin turbo passat wagon, 91 gti vr6, 87 lifted golf, 63 ragtop, 00 jetta,
    10-08-2012 01:25 PM #7
    SEND IT TO ME ill fix it. $100
  8. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    10-08-2012 01:56 PM #8
    Yes, and if the module isn't original to your car it may need to be programmed. Used modules may already be bad, and if not probably will be. Pretty much all the originals fail. Best bet by far is to have YOUR module rebuilt. You can drive without it.
  9. n00b
    Oct 7th, 2012
    98 V6 VW Passat
    10-09-2012 12:00 AM #9
    Thank you so much! I will try the rebuild then I guess...I hope it works!
