Results 1 to 3 of 3
Thread: Valve adjustment
  1. Member 87Cabriolet's Avatar
    May 9th, 2009
    Arizona
    1987 Volkswagen Cabriolet, 1989 Chevy S10
    10-07-2012 04:47 PM #1
    Just wondering if anyone had their two cents to add in on the valve adjustment I am going to do on my car.
    Should I aim to adjust them in the midrange of spec, tighter end, or looser end?
    I assume it is worthwhile to adjust them all to be equally within spec. And I would not want to leave one clyinder looser/tighter than another. Of course if its within spec not a crisis but still minds well do it right.
  2. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    10-07-2012 09:50 PM #2
    If you have 4 journal caps on your head then it is Hydraulic and no adjustment is needed. If it had 5 journal caps then it is not hydraulic and can be adjusted.
    Sticky gummy lifters on a hydraulic head can be cleaned and rejuvenated.
    Here is a hydraulic head see the skipped journal
    Where are my grounds ?
  3. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    10-07-2012 10:40 PM #3
    http://www.driversfound.com/scirocco...lveadjustment/
    we're only talking about .1mm here, you want them all to be within .1mm of each other
