Can som one point me out or have a descent table to get me started , stock 1.8t awp with ms2 extra .
Thanks .
FS:Sunroof Deflector
oughta be able to use the 1.8t spark map on there no problem... fuel will probably need fudging regardless but the 1.8t fuel map on there could be a good start
itll let you drive around and have tunerstudio make tweaks to your fuel table (if youve got a wideband connected to MS, and reading properly), so you can tune and drive the car at the same time... its also a pretty quick way to make changes initially.
if you load the MSQ, then export the table to the desktop, then open your MSQ and import the table, should go easy. If not, you may have to do a prtscrn and edit it manually. Or save the Fuel Table and import that to your tune.
I would download the msq of interest and open in ts with a temp project and export the tables. Trying to port msqs across versions get tricky.
-Paul
#11
Save the Fuel map and import that one.
