Results 1 to 24 of 24
Thread: tranny sound???
  1. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    1998 vw jetta gls 2.0 ABA, 1992 vw cabriolet 1.8, and a 2002 kawasaki 636 zx6r ninja
    10-07-2012 09:57 PM #1
    i have a 92 cabriolet 5 spd and when i drive the tranny is really loud with a whine....it sounds like an rc car but its louder then the stock exhaust any one kno how to stop that sound
    if your ganna be dumb you gatta be tough lol
    tight is tight, to tight is broken
  2. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    '86 Cabriolet G60, '82 280ZX Turbo, '06 325i Problem Child
    10-07-2012 10:04 PM #2
    Fix your leaks and put some more oil in your transmission.
    Or ignore it and destroy 5th.
    It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark... and we're wearing sunglasses.
    -Hit it.
    RooflessVW
  3. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-07-2012 10:29 PM #3
    i dont really use fifth not may places here to lol but ill look in to the leaks .....how would i find them if i may ask
  4. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    10-08-2012 01:01 AM #4
    Get under the car and look up.
    The manual transmissions usually leak from:
    Axle cups.
    Front Seal.
    Push rod seal.
    Rear tin cover.
    Speedometer Cable seal.
    Usually the leaks if not really bad will not drip as most of the leaks drip or leak on moving components and get sprayed on the underbelly.
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  5. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-08-2012 07:54 PM #5
    whats a good fluid to use after i check all of this
  6. Member
    Jun 25th, 2012
    Houston TX
    93 Collector's Edition Cabriolet MT
    10-08-2012 08:52 PM #6
    GM Synchromesh seemed to be the concensus when I was looking to do mine. I am still dripping, need to look at my speedo cable gasket again. Sorry to threadjack, but does anyone use sealant on that seal?
  7. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    10-08-2012 09:06 PM #7
    No, the gasket is cheap and effective.
  8. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    10-08-2012 10:15 PM #8
    Many people like synchromesh-type fluids, even though they are a bit thinner than spec'd for our transmissions.
    I use Honda MTF II. Try, you'll like it. The one catch with it is a shorter OCI. I change the fluid every three oil changes or ~21k miles.
    -Hit it.
    RooflessVW
    Jun 25th, 2012
    Houston TX
    10-09-2012 05:08 PM #9
    Quote Originally Posted by briano1234 View Post
    Yeah I installed a new gasket. I had to put a longer bolt in there to grab some threads, maybe the bolt was too long and it's not fully seated. I'll have a look. Sorry OP, threadjack over!
  10. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-09-2012 08:27 PM #10
    thanks guys
  11. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-09-2012 08:30 PM #11
    Quote Originally Posted by dave93cab View Post
    where did u find the gasket and bolt
  12. Member tolusina's Avatar
    Oct 18th, 2004
    '95 Ranger, '74 Gitane Pista
    10-09-2012 08:37 PM #12
    Is the noise this car makes maybe a wheel bearing??
    Quote Originally Posted by kamzcab86
    I hate reading: "But I bought this car for $500 and don't want to put another dime into it."
    _____________________(hey, it's VW AND it's electrical, what's not to fail?)
    neoBentley+
  13. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-09-2012 09:31 PM #13
    no i kno the sound of a wheel bearing cuz that just started to go this sound is deff from the tranny cuz it started after i changed the tranny awile ago
  14. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    10-10-2012 03:07 AM #14
    wheel bearings sound like grinding rocks at warp speed
    transmission bearings sound like whining (differential)
    the bolt is M7x 1.25
    transmissions leak, even after you replace all the seals
    while everyone recommends Synchromesh...i tried it once
    drained it out a week later and dumped the oil
    went back to 75w90....
    Synchromesh is too light, it leaks more, and whines more
    if you have failing synchro rings it will help aid shifting (band-aid)
    if you have failing input/output/differential bearings only things to fix that is replace the bearings inside the trans
  15. Member
    Jun 25th, 2012
    Houston TX
    10-10-2012 10:04 AM #15
    Quote Originally Posted by rabbitnothopper View Post
    Is there a significant difference in thickness/leaks between the two?
    I'm tempted to try a different oil. I have no strange sounds from my transmission, but no idea how much i have leaked out, so might drain and re-fill when I investigate.
    Quote Originally Posted by mk3jetta-man View Post
    GermanAutoParts.com, I found my email receipt but can't find it on their site anymore, bolt from Lowes!
  16. Member
    Jun 25th, 2012
    Houston TX
    10-22-2012 10:49 AM #16
    Can't find any M7x1.25 bolts anywhere! Any ideas on where to get one? Also, do you happen to know how long it is? Thanks!
  17. Member Darter's Avatar
    Aug 24th, 2002
    West Milwaukee, WI
    02 Passat Wagon GLX 4mo, (sold: 83 Rabbit Convertible Wolfsburg Edition, sold: 99 Passat 1.8T)
    10-22-2012 11:33 AM #17
    Gasket is the 3rd item down:
    http://www.germanautoparts.com/Volks...nsmission/41/1
  18. Junior Member
    Jun 18th, 2012
    Rockton, IL
    1992 Cabriolet, 2001 Jetta Wagon
    10-22-2012 11:57 AM #18
    I just put in a new speedo cable two days ago and couldn't get it to seat properly with the gasket... I wasn't getting any speed readings at all. Without the gasket it seated just fine and I could finally tell how fast I was going. As long as I pay attention to fluids that shouldn't be a problem, right? It seemed like the metal cup of the cable was pressure fit into the hole in the transmission, quite perfectly.
  19. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-22-2012 01:14 PM #19
    Quote Originally Posted by Darter View Post
    thanks u
  20. Member
    Jun 25th, 2012
    Houston TX
    10-22-2012 03:52 PM #20
    Might have solved it (the speedo gasket bolt)
    N0901733 is original part number, called a local dealer said no-one around has one
    It has been replaced by
    N90009201 (Bolt)
    N0122345 (Washer)
    Spec is M7x1.25x13mm
    I'm going to try to order one but I have the feeling I need one a little longer as I think the first few threads have gone in my tranny.
  21. Member
    Jun 25th, 2012
    Houston TX
    10-22-2012 04:17 PM #21
    how about a helicoil kit and be done with it? Anyone have experience with these?
    Can get M8x1.25 bolts everywhere
    http://www.amazon.com/Helicoil-5546-.../dp/B0002SREP4
  22. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    10-23-2012 02:31 AM #22
    dont do it, you'll have metal in your transmission
    i can get M7x1.00 easy but the M7x1.25 arent easy to come by
    been meaning to order some from fastenal or one of the other bolt/hardware companies
    oh, snap-on...that company
  23. Member
    Jun 25th, 2012
    Houston TX
    10-23-2012 10:09 AM #23
    I called my local fastenal yesterday and no luck from them. I'm going to have a good look at the position of the hole tonight and decide if there's a way I can drill with surgical precision and seal the area up while i'm doing it.
    The drip I have is annoying as hell, I can't park my car outside because it fouls up the paving. Gonna have to drain and fill the tranny again too. I'll probably switch to some 75w90 if it is less prone to leaking. Haven't been driving my cabby much, I want this solved once and for all
  24. Member mk3jetta-man's Avatar
    Apr 15th, 2011
    stroudsburg. PA
    10-23-2012 01:45 PM #24
    ya i kno how u feel about the leaking on the pavement....i also have a slow drip in my oilpan from the drain plug i gatta get a new pan one of these days
