UPDATES
Okay So here are pictures of what I've seen when doing this first inspection. Anything else I should look for?
So the sensor itself Looks pretty Corroded. But the Fuel Sending Unit is dry!
#36
Do it right, or do it twice.
http://www.fancy-this.ca
The F N Pothole Build!///ORT///AirSociety///CTS Turbo
#37
UPDATES
#38
I see what you are saying... only contradiction then is they say that the MK3 and the new MK5+ wiring does not have this problem because there is no sleeve behind the plug same as that gas plug really... I don't know i guess it is possible but it just seems so unlikely...
#39
[QUOTE=Brandon_Schulze;79287614]UPDATES
QUOTE]
your finger hair reminds me of sand crabs in florida....
i like sand crabs in florida![]()
i want my Dub lower than my self esteem!
#41
#42
The cooling system pressurizes. In the mk4 there is a seal meaning the pressure pushes the coolant into the wires. No seal = pressure leaks out around the plug.
Its not the sleeve, its that orange seal in the picture on the inside of the plug. A quick fix is to pull that out and boom its like a mk3 or mk5 plug.
#43
AIR is short for Airblaster, its a snowboard company from Portland haha.
#44
Anyone have input on the pictures I posted? I need help still!
#45
Is there a CEL?
Scan the car to see if there are any underlying codes?
#46
Came back to see if pics of neighbor had been posted. I'll be back in 24 hours to check again.
#47
#48
#49
Also, pretty crazy that he lives next door to my girlfriend![]()
#50
No CEL... But that plug looks pretty bad.
#51
Aaaanyone?
#52
FAQ'd under 'coolant migration'
My Build
Welcome to the world of racing! Budgets are ALWAYS exceeded, deadlines are never meet, end-goals never reached, and wives always unhappy... it's all worth it though!
#53
My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESSPAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
#54
Thank you!
If you have a de-pinning tool I would take those pins out and clean them up, probably put some electrical contact sealer in there to prevent corrosion again.
Starting to lean towards a faulty cluster? Anyone? Input?
To rule out the wiring from the fuel sender I would test with a volt meter to make sure that they arent grounding.
When is the problem happening, at startup? When the car is cold? When its hot?
How's the battery on the car? When was it replaced?
#55
#56
After a bit more digging I think a coolant flush and new ball will suffice. I'll clean and reseal that plug and hopefully that fixes her problems?
A faulty cluster is going to be an expensive repair.... right?![]()
#57
Anyone? Will that work?
#58
#59
#60
I've just been reading up about this problem and trying to get edumacated on the subject. Hey OP, what ever happened with this?![]()
#61
#62
The one on the right is pretty hot
FS - OZ M-191 Center Cap - http://forums.vwvortex.com/showthrea...5#post77384355
Diesel Dub Club #38 || Euro Style || MK2 Militia ||
