IIRC the inlet is the same size. Some years came with a larger or smaller PCV piece so that should be the only factor on fitting a TIP.
#1
looking at buying a neuspeed turbo inlet for my jetta 1.8t, i got the ko3s it being a gli
will a tip from a regular ko3 fit? I've searched everywhere
#2
#3
My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESSPAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
#4
i had one before.. really didn't like the way it fit with the stock intake.
#5
like look at this
http://www.ecstuning.com/Volkswagen-.../Hoses/ES5981/
says the stock pipe fits the ko3 and ko4.. how thought.. what about the ko3.. this is so confusing..
also on neuspeeds website.. there are 2 different inlets with 2 different part numbers
