Results 1 to 2 of 2
Thread: 2000 Jetta/Bora Auto Gearbox problem??
  1. 10-08-2012 10:19 PM #1
    Hi guys, have a bit of a problem with the 4 speed auto in my 2000 VW bora/jetta.
    Went to drive the car the day after taking it to a mechanic for something unrelated and could not really find any gears.
    Going down the gearstock the gears are out of alignment, example Drive is park reverse if neutral ect.
    if i go all the way down to gear 1, this indicates on the dash as being gear 3 and going up all the gears engage Position 1 = gear 3, Position 2 = gear 3, Position 3 = gear 3, Position d = drive, Position n = neutral, Position r = reverse and Position p = park.
    Going down however, few gears engage and they are all over the place. The car drives fine except except for the slight hesitation/hold for split second too long from 2nd to 3rd which it has been doing since i bought the car.
    Thinkingf maybe something to do with teh linkage perhaps except not too sure how this operates on an auto compared to a manual which i know is a common failure amongst some cars
    Car has 110,000 kilometres (around 70,000 miles)
    thanks!!
  2. Member CoolAirVw's Avatar
    Mar 8th, 2007
    Kansas City Missouri
    85 Jetta TD sold 2001 Jetta Tdi, 2000 Jetta Tdi
    10-09-2012 10:57 AM #2
    have a helper move the shifter while you are under the hood looking at the linkage.
    Auto trans fluid change or flush will not make a trans fail. Stop spreading the wives tale/urban myth.
    ASE Master Certified Technician with L1 Advanced Diagnostic Rating Recently passed ASE certification for Light Diesel repair.
    www.KansasCityTdi.com
