Results 1 to 15 of 15
Thread: E46 M3 preventive maintenance question
  1. 10-09-2012 02:46 PM #1
    I did not want to interrupt the E36 thread with off topic questions. So, I'll ask it here; What are the preventive maintenance items that should be looked out for when purchasing an e46 M3? Besides the subframe welding issue, what else should be looked for? Suspension refresh kit?
  2. 10-09-2012 02:55 PM #2
    Your best approach by far would be to find a good local indy BMW mechanic and ask him. Then use him for a thorough PDI when the time comes.
  3. Geriatric Member ATL_Av8r's Avatar
    Oct 17th, 2002
    Gapiana
    10-09-2012 02:56 PM #3
    Up to production date 10/01 there was a recall on connecting rod bearings.
    Also ask for service records for oil changes and note that Castrol TWS 10w-60 was used and that interim oil changes were made between the "free scheduled maintenance" BS every 15k.
  4. Member GTIolot's Avatar
    Aug 13th, 2003
    Black Rock City
    '03 VW GTi 1.8t(RIP) '97 M3 Coupe
    10-09-2012 03:43 PM #4
    http://forums.bimmerforums.com/forum....php?t=1468749
    Here is a link to the Bimmerforums "Everything you should know before buying a E46 thread"
    I used a similar guide to buy my E36 M. Still had a PPI done, but this allowed me to ask the right questions and find a car that was well taken care of.
    -WaterCooledMilitia-
  5. 10-09-2012 03:52 PM #5
    Thanks it looks like ECS has that oil change kit here.
  6. Senior Member absoluteczech's Avatar
    Sep 12th, 2006
    Newport Coast, CA
    2013 VW GTI 2DR DBP
    10-09-2012 04:04 PM #6
    depending on miles make sure the valve adjustment was done and has been done
  7. Member zmt's Avatar
    Dec 7th, 2001
    DFW, TX
    '07 335i, '06 T&C, 07 Z4MR
    10-09-2012 04:04 PM #7
    S54 needs periodic valve adjustments. Plan on doing one right when you get the car for peace of mind.
    There's also been multiple instances of the intake side VANOS camshaft bolts backing out/shearing which can nuke the engine. No idea of failure rates, and if I can grow a pair I'm going to check mine out when I do my valve adjustment.
  8. 10-09-2012 05:43 PM #8
    Quote Originally Posted by zmt View Post
    Are the periodic valve adjustments a DIY item?
  9. Senior Member absoluteczech's Avatar
    Sep 12th, 2006
    Newport Coast, CA
    2013 VW GTI 2DR DBP
    10-09-2012 05:45 PM #9
    Quote Originally Posted by Remedy View Post
    if youre skilled and have the right tools (shims, etc)
    http://bit.ly/VXF1vI
  10. Member zmt's Avatar
    Dec 7th, 2001
    DFW, TX
    10-09-2012 06:12 PM #10
    If you have a garage and can either buy the shim kit and tool, or if you have the time to order the specific shims you need, sure! Once you have the valve cover off it's really nothing more than removing pucks/measuring/replacing pucks.
  11. Member compy222's Avatar
    Apr 7th, 2005
    Pothole, MI
    2012 Cruze Eco, 2006 Lancer Evo IX MR
    10-09-2012 06:34 PM #11
    a ppi is a must. the more service records, the better!
    Regarding DD'ing a tuned Evo:
    Quote Originally Posted by SchrickVR6 View Post
    It's composed at all speeds and at all times...it just feels like you're holding the leash on a 150lb pit bull and praying you don't see a squirrel.
  12. 10-09-2012 09:04 PM #12
    Hmm... It sounds like a person would have their work cut out for them with an e46 M.
  13. Member BTM's Avatar
    Feb 19th, 2007
    Des Plaines, IL
    #2Fordz
    10-09-2012 10:09 PM #13
    Valve adjustment is definitely DIY-able for any semi competent. It looks more intimidating than it is. BMP design has a couple of videos on youtube I basically used exclusively for my directions on how to do it.
    If you still think it's over your head, should only be 4-5hrs at an indy shop (not bad every 30k or so, if you ask me)
    -Brian
    BMWCCA, SCCA, CCSCC
    Current: 2014 Mustang GT, 301A, Track, Recaro; 2006 F-150
    Past: 2007 Z4 M Coupe, 2007 E90 335i, 2002 Hyundai Accent, 2001 Volvo S80, 2001 Daewoo Nubira (seriously), 1999 Ford F-150
  14. Member
    Aug 13th, 2008
    Minneapolis, MN
    1995 M3, 2012 GLI
    10-09-2012 10:21 PM #14
    OP, are you kidding me? This stuff is incredibly well-documented on the internet. By this point, we know virtually everything about the E46's weak points.
    This checklist took me less than 10 seconds to find via Google:
    http://edgemotorworks.com/wordpress/...ing-m-edition/
    DD: 2012 GLI
    Gone but not forgotten: 2010 Golf 2.5
    Summer fun: 1995 M3
    Former E36 318i driver and self-appointed Chairman of the Momentum Preservation Society.
  15. Member dmorrow's Avatar
    Jun 9th, 2000
    Cincinnati, OH
    '06 Audi A3, '06 BMW Z4M Coupe
    10-09-2012 10:38 PM #15
    If you want to really learn about an E46M there are much better places to spend your time than here.
    If you are going to daily drive this car and are looking for cheap transportation it probably isn't the best choice.
