Results 1 to 9 of 9
Thread: new to sciroccos help
  1. Junior Member joshsnudden123's Avatar
    Feb 13th, 2012
    85 vw scirocco
    10-09-2012 10:14 PM #1
    hey guys so i have a prob with the idle screw unscrewing its self and making my idle up to 3k is there any way i can get it to stay in place ??
  2. Member sciroccojim's Avatar
    Dec 21st, 2004
    NJ
    1980 VW Scirocco S Callaway Turbo
    10-09-2012 10:45 PM #2
    A new o-ring on the end.
  3. Junior Member
    Aug 3rd, 2012
    Chicago
    '88 VW Scirocco 16v
    10-09-2012 11:07 PM #3
    this happened to me the other day after driving it hard, I just took a bit of pipe thread tape and it did the trick
  4. Junior Member joshsnudden123's Avatar
    Feb 13th, 2012
    85 vw scirocco
    10-09-2012 11:12 PM #4
    thank you guys ill give it a shot
  5. Member Eistreiber's Avatar
    Dec 10th, 2006
    Northern Colorado, USA
    5x Mk1 Sciroccos, and a ('91) Toy Twuck
    10-11-2012 11:18 AM #5
    Quote Originally Posted by sciroccojim View Post
    That ^ x2.
    Fit should be 'snug', and a dab of Castrol Rubber Grease will help ease it in without damage/ binding.
    You should find a good selection of O-rings at a local hardware store, or you can try a Caterpillar dealer. If you have the old O-ring carefully remove it and use for reference.
    When a man tells you that he got rich through hard work, ask him: 'Whose?' -Don Marquis
  6. Member sciroccohal's Avatar
    May 4th, 2005
    Infrared AZ.
    '78,81S,TTQ,S2 8V, race Corvette
    10-11-2012 01:36 PM #6
    Quote Originally Posted by KRaddatz View Post
    Your Throttle body is under VACUUM....teflon pipe thread tape is not so good when it unravels and gets sucked down into the cylinders...
    Get a new o-ring.....4 cents.
    The feeling of immortality extends right up until the moment of impact.
    I cannot teach you how to be a Zen mechanic, grasshopper.
    The VW Scirocco, the worlds fastest ECONOMY car.
  7. Member bside1978's Avatar
    Aug 16th, 2007
    Vancouver, BC
    83 Scirocco - 89 Jetta GTX
    10-11-2012 02:08 PM #7
    http://www.ebay.com/itm/Vw-Rabbit-Sc...c5441d&vxp=mtr
    A great source for little random parts...
  8. Junior Member
    Aug 3rd, 2012
    Chicago
    '88 VW Scirocco 16v
    10-11-2012 02:27 PM #8
  9. Junior Member
    May 9th, 2011
    Scotland
    1989 Scala i
    10-11-2012 02:53 PM #9
    They are also available from the dealer.
