Results 1 to 5 of 5
Thread: Misfire/popping with no CEL
  1. Semi-n00b
    May 27th, 2010
    Thomaston, CT
    2006 Rabbit 2.5L ; Previously 2001 Golf Mark IV 2.0L
    10-10-2012 07:19 PM #1
    About a week ago I turned on my 2.5 Rabbit and found it idled very rough. Seemed like a cylinder was misfiring. Stepped gently on the throttle and it went away. Since then I've noticed what feels like a misfire under acceleration, especially when cold, and an occasional "popping" noise when I let off on the throttle. I'm also had a 2+ mpg decrease in fuel economy. Any ideas where to start?
  2. Senior Member
    Feb 28th, 2002
    chicagoland
    91 GTI 1.8t, 07 Rabbit
    10-11-2012 04:55 PM #2
    How old are your plugs? I don't know if that is a great start but its a start.
    Quote Originally Posted by VikingVR6GTI View Post
    Yep, that was my first thought too. A nice set does not automatically make a chick attractive. Especially when that "chick" is a dude.
    Buy my 1954 GMC Truck
  3. Semi-n00b
    May 27th, 2010
    Thomaston, CT
    10-18-2012 03:47 PM #3
    Quote Originally Posted by spdfrek View Post
    They're original. Everything is original on the car but the rear brakes and two sets of wheel bearings. I've got 85k on it and have never had an issue (well, not since a defective clutch plate tore up the transmission at about 3k).
    I took it in to my mechanic today and he couldn't find anything wrong with it. It has smoothed out quite a bit since I refilled it, actually, and I'm wondering if I just had a bad batch of gas. Think I'll add a bottle of fuel-injector cleaner and see what happens.
  4. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    10-20-2012 06:02 PM #4
    You need to go maintain your car. Fuel filter, plugs, coils, air filter etc...fix it by doing the needed work
    Sent from the bottomless pits of HELL!
    god i love my car. it may not be fast, but it's crazy fun!
    C2 stage 2 TURBO!!! ACHTUNG!!! 2.5liter 5cylinder contents under pressure!!!
    Nov 28th, 2010
    07 Jetta WE, 07 F-350 6.0
    10-20-2012 08:29 PM #5
    Original plugs at 85k!? You should be on about your 3rd set by now...
    UM Stage 1 Tune | APR Carbonio Intake | BFI Stage 1 Mounts | ECS Lightweight Underdrive Pulley | NLS Short Shifter | 42DD Bushings | Beetle Engine Cover
