#1
2002 1.8TQ AMU
Raven Black Pearl Effect
Black Heated Leather
6-speed manual AWD
95,xxx Miles (Daily Driven)
Located in Ocean County, NJ
Clean Title in Hand
Maintenance (Past 3 Months)
Timing Belt & Water Pump by previous owner @ 83K
Clutch w/ OEM weight single-mass flywheel
Geomet coated Rotors
Akebono Ceramic Pads (No brake dust)
Valve Cover Gasket (Fel-Pro)
Coil Packs
Spark Plugs
Coolant Reservoir
Coolant Flange
G12++
Amsoil Synthetic 5w-40
Mann Filter
Fuel Filter
Passanger-side Axle (Ripped CV boot)
Boost Leak Test
New Vacuum Hoses
New Wiper Cowl
New Oil Dipstick Funnel
Bosch Icon Blades
Mods
K&N Drop in Filter
Forge Inlet Pipe
Forge 007 DV
BFI Dog Bone Mount
Unitronic Stage 1+ Tune (Advertises 273HP / 275LB-TQ @22psi)
Full Emissions Delete
PCV Edit
Misc
Wrinkle Paint Valve cover, Charge pipe, Intake manifold
Forge Polished Oil & Water Caps
Paint Matched Filler Plate
Full Ziza LED Lighting
Monster Mats
Aux Input
IE SAI Blockoff plate
IE OEM style resistors
Forced "Readiness"
NO CEL'S!!!!
Bad
Cluster is Pixely
________________________________________________
Car was Clay Barred and Black Box waxed.
Everything works normally; Heated Seats, Heat, AC, Cruise Control, Power Windows ect....
Also comes with all the original parts; Inlet Pipe, DV, Floor Mats, Interior lights ect....
NJ Inspection good till 07/14.
Tires have plenty of tread.
On To The Pics
This car was properly maintained, runs great, very comfy, turns over every time and will pin you to the seat.
Selling because I want something a lil bigger (B7 A4)
Price
$12,000 obo
Contact Joe via PM or Text/Call anytime @ (609)-618-9526
Thanks for looking
Specialized paint correction and protection for NJ, Fidelity Finish
