VWVortex.com - No love for the mid-wides..
    Results 1 to 9 of 9
    Thread: No love for the mid-wides..
    1. Banned
      Sep 18th, 2012
      40.8033° N, 76.3417° W
      If I told you I'd be banned from TCL
      10-12-2012 01:47 AM #1
      When it comes to snowboarding I HATE having big feet...my feet aren't even that big..11-11.5 in vans but 12 in board boots. Besides Burton anyone know of a brand running some type of shrinkage tech? I'm trying NOT to run a mid-wide for the lack of good boards. Ideal board is Captia BSBOD or Outdoor living...think I can make it work? Anyone have experience with risers?
      Dec 30th, 2003
      NNJ / NYC
      10-17-2012 10:18 AM #2
      I'm lucky as I wear a 9.5 in almost all shoes/boots, so I've never had a problem.
      I have two friends that have big feet (~12) and they have the same problem as you. I know that Salomon, Ride and DC all 'say' they have some kind of shrinkage tech for their boots, but the tech (and size decrease) varies for each brand.
      Unfortunately (for sizing issues like yours).. the only way to find the right boot is to go out and try on everything you can. Comfort > Size, but maybe you could take a small tape measure with you to test the actual footprint for different brands of the same size boot.
      As for using risers... I have no personal experience, but what's more important to you?? Having a slimmer board or having more direct contact with the board?
      Personally, I'd pick up the best (read: most comfortable) boots I can and then check out different boards (Wide / Mid-Wide) - and Regular because different manufacturers all have different widths - and I'd get one that allows me to use my stance without a riser pad.
      Good luck!!
      - Matty
    3. Member simple's Avatar
      Mar 29th, 2001
      Golden, CO
      Subaru OB XT, Sportsmobile Van, Mazda CX-5
      10-18-2012 08:04 PM #3
      I have the same problem. Salomon with Fusion construction are the best at getting your boots down to a smaller size. Only issue is that the liners are not removable. I've used the F20 and F22 and loved them both.
      Unfortunately for 2013 only one Salomon boot has Fusion and that is the F3.0 and that boot is ugly!
      I tried a pair of Ride Jackson boots and I was really impressed with how they fit. Low weight and narrow. Only problem for me is I want a 7/10 stiffness minimum for all the backcountry I do.
      Oh and Risers on snowboards are stupid.
      If you can't measure it, you can't understand it; if you can't understand it, you can't control it.
    4. Member Mr. Nobody's Avatar
      Oct 22nd, 2002
      San Diego, CA
      2013 Golf tdi, 1972 Porsche 914
      11-18-2012 05:26 PM #4
      I've since switched to skiing buit back when I did board I had a 154 Rome Machine that was a blast to ride and wide enough to handle my size 12 boots.
      Just saying. Good luck finding a set of boots that work.
    5. Member 2.0BePopN's Avatar
      Nov 11th, 2010
      morris county, new jersey
      97 gls
      12-07-2012 12:55 PM #5
      I have a size 12, im riding a forum board at 156, and i have my stance set duck foot (most park riding) , it gave me less toe overhang ( isnt much at all) and no toe drag whatsoever.
    6. 02-01-2013 11:03 AM #6
      I'm size 11/12 running a 32 boot on a ride DH2 wide, and love it, but I am comfortable running a HUGE duckfoot stance.
      I more frequently use my beater board though, which is an old Atomic Hatchet with a chunk out of the bottom from catching a rock while teaching some kids, lol. It has a bit more trouble with toe drag...
    7. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      02-06-2013 12:47 PM #7
      i have size 14 boots and haven't bought a wide snowboard in ages. my last 3 have been standard widths or possibly mid-wides, but i no longer shop for a true wide.
      the amount of toe drag i have really isn't that bad. if i'm making some very aggressive toe-side turns i can purposely create toe drag, but it's never caused me too many problems.
      generally what i look at most when buying a new snowboard is the waist width measurement. this will affect how much toe drag you end up with. most wide boards measure in at 260mm+, but my current board (Signal Park Flat) measures to 246mm and my previous board was 252mm. Having a decently thick sidewall on the edges will help alleviate toe drag as well since your foot will be raised higher off the snow. you can also see if it's possible to shift your binding back a bit,. this may create the potential for more heel drag, but ive found it's much harder to carve deep enough to drag your heels on a turn that your toes.
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
    8. 02-07-2013 12:43 PM #8
      Quote Originally Posted by Clean PG View Post
      I apparently used to have my bindings set up this way (unintentionally) and it has led me to become much more conservative on my heel edge than my toe, which is not a good thing if you really want to progress.
    9. Member koston.'s Avatar
      Aug 20th, 2003
      Smell you laterville, Bellevue WA
      1996 VW GTI, 2005 Forester XT
      02-18-2013 06:49 PM #9
      Love my Burton driver X boots... but I think quality goes down each year. I still have a set from ~2002, when I think Burton was hitting their stride. They seem quite a bit smaller than what I cam from (Vans... ugh)
      Shutup and drive yo cah'!
