Results 1 to 7 of 7
Thread: Leaking water neck.
    Jun 1st, 2011
    Holiday FL.
    1988 cabriolet
    10-12-2012 11:01 AM #1
    ok the water neck off the drivers side of the head to the heater core is leaking, pretty bad, i have to put in water everyday now....dont know if the neck is broken or just the seal...
    what is the part called, anyone know? so i can grab a new one....
  2. Junior Member
    Jul 31st, 2012
    Columbus, OH
    '92 Cabriolet
    10-12-2012 11:17 AM #2
    Sounds like the hose flange. $1.12 at autohaus
    Jun 1st, 2011
    Holiday FL.
    1988 cabriolet
    10-12-2012 11:35 AM #3
    thats it....thank you!!
  4. Junior Member
    Jul 31st, 2012
    Columbus, OH
    '92 Cabriolet
    10-12-2012 11:56 AM #4
    No problem. Mine leaks pretty bad too, along with the all the other flanges!
  5. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    10-12-2012 12:20 PM #5
    Get thee to a wrecking yard, or ebay, and get one from a older diesel rabbit, as they are metal, and will not be prone to leakage ever again.
    Mine had distorted, and got out of round due to age and heat.
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  6. Member
    Jun 1st, 2011
    Holiday FL.
    1988 cabriolet
    10-12-2012 01:46 PM #6
    good advise!...the hunt is on!!
  7. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    10-12-2012 08:01 PM #7
    Quote Originally Posted by Smallchange View Post
    wow that is EXTREMELY cheap......
    agreed, prefer the metal ones
    although in contrast the bolt holes can crack...but so does plastic
    meh
    for a buck fiddy youre fixed for now
