Results 1 to 8 of 8
Thread: center brake light cover
    May 16th, 2004
    1986 16v Rocco
    10-12-2012 11:07 AM #1
    is the center brake light cover glued on?
    my red lens fell down and I want to put it back but not sure how to do so.
    the rear pops out sure but the the rest come s off how?
  2. Member VWsEatRice's Avatar
    Jan 13th, 2004
    Tacoma WA
    84 Jetta GLI, 86 Scirocco 16v
    10-13-2012 02:11 PM #2
    x2.
    i can get the lens out but can't figure out how to remove the black plastic housing to clean the window.
    [IMG][/IMG]
    May 16th, 2004
    1986 16v Rocco
    10-13-2012 08:11 PM #3
    no one knows? hal? doug t? cuppie? someone?
    I can't be the first to need to remove this
  4. Member cuppie's Avatar
    May 3rd, 2005
    Redford, MI
    88 Scirocco 16v (Wilda); 86 QSW (still unnamed); 90 325iX (Nina - kid's car)
    10-13-2012 09:28 PM #4
    It all just snaps together. Really.
    It's been a while (and, I don't feel like wallking thru the rain to the garage, pulling the cover off, and playing with it again...), but...
    Pop the bulb carrier off (you've got that far.)
    The reflector is held in by a snap-tab or two on each end (?) - should just need a small flat-head screwdriver to release it.
    I don't remember if the housing is bonded to the glass, or secured with spring tabs. Some little corner of my mind, though, says that it was bonded.
    Anyhoo, once the reflector & lens are out, the hole is big enough to reach thru & clean things.
    - Cup
    '88 Scirocco 16v, 'tastefully' modified.
    things currently broken (Scirocco): 3
    things currently broken (QSW): too many; but, slowly getting better
    May 16th, 2004
    1986 16v Rocco
    10-14-2012 05:22 AM #5
    the cover i can feel has a little movement like it snaps in
    I was afraid i'd go to pull it down and it was supposed to be pushed back and i'd break the tabs.
    theres no clear way it comes out i'll let everyone know when i pop it out
  6. Member VWsEatRice's Avatar
    Jan 13th, 2004
    Tacoma WA
    10-14-2012 01:00 PM #6
    Quote Originally Posted by euroteknique View Post
    good luck.
    May 16th, 2004
    1986 16v Rocco
    10-22-2012 09:56 PM #7
    ok i think i figured it out almost
    how to fix the lens:
    once the back cover is removed you can feel the reflective housing where the bulbs go into
    this removes by pulling on it it. i grabbed and kind rotated it down and it popped out
    with this i was able to put the red lens back on in the pic below you can see the tabs holding this in place
    on the sides i noticed i could stick my fingers into a hole pic below
    looks like there is a tab or some sort of piece to hold the cover on. I might be completely wrong
    I tried for a moment but it was dark out
  8. Member sciroccojim's Avatar
    Dec 21st, 2004
    NJ
    1980 VW Scirocco S Callaway Turbo
    10-22-2012 10:42 PM #8
    There are two metal mounting tabs glued to the glass. You can see them in the above pic but can't see them from the outside of the car, due to the black paint on the glass. The entire brake light assembly slides onto the tabs and clips into place. I'm almost positive that it slides on from the top. You can pry gently on the plastic tabs and slide the assembly off of the clips.
