VWVortex.com - So My Keyless Entry Stopped Working
    The Car Lounge
    Results 1 to 19 of 19
    Thread: So My Keyless Entry Stopped Working
    1. Member HaterSlayer's Avatar
      Oct 18th, 2007
      Lithonia, Ga
      00 Pontiac Grand Prix GT Coupe
      10-12-2012 07:54 PM #1
      I have an odd problem in my GP. As the title says my keyless entry stopped working. We took the fob to the dealer thinking it was a battery. They said the fob was fine so it is the car. What part of the car gets those signals? I thought it was just the antenna or something. Would replacing that part be expensive?
    2. Member elite.mafia's Avatar
      Mar 17th, 2010
      I95 Northbound
      2003 Hyundai Santa Clause
      10-12-2012 07:57 PM #2
      Just use the key.
      I use @Uber to make money with my car & you can too! Use this link to sign up: http://ubr.to/1VsgDmX
      Earn $750 for signing up to drive with @Lyft in Boston! https://www.lyft.com/drivers/MICHAEL749602
    3. Member Live-Wire's Avatar
      Jun 9th, 2005
      Georgetown Ontario
      2015 Mazda CX-5 GT, 2012 Dodge Journey 3.6 R/T AWD
      10-12-2012 08:40 PM #3
      There would be a receiver somewhere in the car. If you knew what/where to look you could go to a pick and pull yard if they have any in your area.
      Not sure how GM keys these things - certain radio frequency, might have to program the receiver to the key. There are millions of cars with these things out there, but only one set of keys works with one receiver (you don't see other GP's un-locking when you hit your button). But I would imagine the re-program is fairly simple... like a garage door transmitter. Something made as a matching pair would be very difficult to handle logistically. When I had my Audi the only thing you had to do to re-program a key was hit the lock button, then lock with the key, then press the lock button again. Or something to that extent. Might be similar with a GM?
      I'd ask the dealer what would be involved, and then look into your options. Also, it could just be a corroded connector on the receiver, or a faulty relay from one of the outputs (does the central locking still work from the interior switch)... could be any number of things on a 12 year old car. Seems like something you'd need a full GM scanner to track down (to see if the receiver is taking commands). If the receiver works, but the car isn't sending an unlock command to the door locks, it could be the output, a relay, the solenoid, or wiring in the middle. If its plain and simple the receiver - check for faulty wiring, then replace the part if it is the part itself.
      That being said... if it's more then you want to spend right now, there's always the key. If the central locking still works (and you don't have to push the button down/up for each door) I could live with no transmitter if it were me. Having to do each door manually does suck (I had a Mk2 Golf with manual locks... it wasn't fun, but you deal with it) and I'd fix the central locking.
    4. Member pontiac's Avatar
      Aug 3rd, 2009
      Nova Scotia
      Econoboxes
      10-12-2012 08:48 PM #4
      Quote Originally Posted by Live-Wire View Post
      Most GM's are done like this:
      Close all the vehicle doors.
      Insert the ignition key into the ignition lock cylinder.
      Press and hold the DOOR unlock switch.
      While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
      Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
      Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds , the doors will lock and unlock to confirm the programming of that transmitter.
      Other than that I'm of no assistance.
    5. Member HaterSlayer's Avatar
      Oct 18th, 2007
      Lithonia, Ga
      10-12-2012 09:00 PM #5
      Thanks guys. In my searches I've found the reprogramming thing too. I just need to find the receiver to see if I can replace it myself if need be.
    6. Member Sonic303's Avatar
      Nov 13th, 2009
      5280 ft above you
      Jetta, M3, S4
      10-12-2012 09:33 PM #6
      You don't want to put your key in the car like a freakin animal, now do you?!
      Quote Originally Posted by LG6R View Post
      Got any Viagra so you can go **** yourself?
      Bluewater Performance
    7. Member ambit's Avatar
      Feb 2nd, 2004
      Royal Oak, MI
      05 CLK55 AMG
      10-12-2012 10:01 PM #7
    8. 10-12-2012 10:18 PM #8
      Check under the carpet near the rear window for the receiver.
    9. Member 8v deathsquad's Avatar
      Jan 8th, 2005
      SLC, UT
      10-12-2012 10:26 PM #9
      Really? A feature on his car that he uses often fails, and people give him sh*t for wanting to fix it?
      I live on the edge... of town
    10. Member VertigoGTI's Avatar
      Apr 1st, 2001
      Nati-licious
      10-12-2012 10:53 PM #10
      Problems are never solved in TCL... only mocked.
      Quote Originally Posted by Surf Green
      The real world is more ruthless than TCL, and sensitivity was never one of Darwin's strong points.
    11. 10-12-2012 10:57 PM #11
      Quote Originally Posted by VertigoGTI View Post
      I tried.
    12. Member Spell Check Desk's Avatar
      Mar 22nd, 2001
      Timbuk 3
      10-12-2012 11:47 PM #12
      Try having the dealer reprogram the skim module and then reprogram the fobs.
      Sent from a cup & a string using a Sharpie
    13. Member HaterSlayer's Avatar
      Oct 18th, 2007
      Lithonia, Ga
      10-13-2012 02:26 AM #13
      Quote Originally Posted by Air-over-water View Post
      Thanks for looking that up for me, but that is the wrong gen GP.
    14. Member MrRoboto's Avatar
      Jul 26th, 2000
      VHHH
      E82M & V40 T4 R-Design
      10-13-2012 02:38 AM #14
      There is only one solution...it's time for a new car.
    15. Member
      May 3rd, 2012
      Brooklyn, NY
      MetroCard
      10-13-2012 02:51 AM #15
      Keyless entry stopped working?
    16. 10-13-2012 06:09 PM #16
      Quote Originally Posted by HaterSlayer View Post
      It still might be located under there.
      I was looking for the 2000 model but that was the only image I could find.
      Worth a shot.
    17. Member s-rocc's Avatar
      Nov 26th, 2001
      reassembled in a garage, pa
      bunch of old german junk
      10-13-2012 06:14 PM #17
      Happened on my dad's 2009 avalanche. he figured it was the battery in the fob, but after changing it the problem persisted. he called the dealership who told him it was some kind of mess up in the receiver in the truck. their advice was to disconnect the battery for half an hour, the re-connect. after doing that the keyless works again.
    18. 10-13-2012 06:16 PM #18
      Quote Originally Posted by s-rocc View Post
      It reset the receiver, at least that is my bet.
      Just like resetting the ECU.
    19. Member BetterByDesign's Avatar
      Sep 7th, 2004
      morgan hill, ca
      E46 320, MK IV GTI
      10-13-2012 07:11 PM #19
      You know, 10 years from now there's gonna be people that won't know how to pump air in tires, how to turn on the wipers when it rains or how to enter or start a car using a key.
      Honking at one Camry at a time
