Results 1 to 14 of 14
Thread: Warming up the car but having it not stolen
  1. 10-13-2012 08:19 AM #1
    I have the HIGHLINE TDI 2011 and I want to warm it up in the morning but lock it at the same time…
    I have those keys where I can just approach the door and have it unlocked BUT it doesn't work when the car is locked from the inside…
    …Is there any way to lock/unlock the car with the keys if it's on and locked from the inside?
  2. Member I800C0LLECT's Avatar
    Mar 12th, 2012
    Williamsburg, VA
    2012 Jetta TDI & 2012 Passat TDI
    10-13-2012 08:50 AM #2
    "Warming up" a TDI is useless. You'll be wasting diesel.
    http://www.tdiclub.com/TDIFAQ/TDiFAQ-2.html
    In that link above choose "C" and it will explain.
    Also...engine break in...
    http://forums.tdiclub.com/showthread.php?t=252501
    Jul 3rd, 2006
    Toronto, ON
    2011 jetta tdi
    10-13-2012 09:03 AM #3
    if your that worried about warm up which on this car is useless just use your block heater.
  4. 10-13-2012 10:40 AM #4
    Actually after 10 min the car was blowing warm air and I wasn't freezing so even though I appreciate you guys replying, my question was about locking and unlocking the car with the key while its locked from the inside. The only way to do it now is to break open that piece on the door and insert key..
  5. Member itskohler's Avatar
    Jan 7th, 2011
    Jacksonville, FL/Dallas, TX
    2012 Jetta, 2008 Jetta RIP
    10-13-2012 10:50 AM #5
    Quote Originally Posted by kurolap View Post
    Correct. VW started doing this for their keyless systems on the MY10 CCs.
    Sent from my SGH-T989 using Tapatalk 2
  6. Member I800C0LLECT's Avatar
    Mar 12th, 2012
    Williamsburg, VA
    10-13-2012 10:45 PM #6
    Oil is designed to do it's job at around 200 degrees. Your engine was designed to work with the oil at that temperature. Although it can be considered a bit ocd...running the oil cold means the viscosity is out of spec from what the engine prefers. This cold oil can cause additional wear on your engine parts.
    That's why you generally drive easy and keep rpm's low prior to oil reaching operating temperature so that you can mitigate the engine wear; and even, if you own a tdi, avoid idling as much as possible until the engine has warmed up. I understand your question is far different from the information a few of us provided. We're just trying to give you a heads up.
  7. 11-27-2012 10:13 AM #7
    Hi guys
    Just picked up a 2013 GLI last week and I have a similar question. Its freaking freezing here now and I want to warm the car up for a couple minutes before I jump in. Notwithstanding the pros/cons of this I have a question.
    I find that once I start the car and leave it running I can't lock it from outside of the car with neither my key fob or the door sensor. Can this be enabled? I went through the convenience options and could not find an applicable option.
  8. Member cbdr18's Avatar
    Jul 18th, 2007
    HOUSTON, TX
    2013 VW GLI
    11-27-2012 10:49 AM #8
    lol where do you guys live that you have to worry about your car being locked???
    2013 VW GLI DSG / STAGE 2 APR / AFE INTAKE SYSTEM / BSH THROTTLE BODY PIPE / USP DOWNPIPE / DOG BONE INSERT / FORGE DV SPACER / SOUTHWEST HOUSTON TEXAS
    ADD ME IF YOU PLAY FIFA! PSN: CBDR19
    Apr 4th, 2012
    Sacramento, CA
    2012 GLI Autobahn DSG Black Metallic Pearl
    11-27-2012 11:49 AM #9
    Quote Originally Posted by cbdr18 View Post
    Yeah and in the morning at that. Are car thieves even up that early?
    GIAC - Stage 2 // SPM Street Downpipe // Neuspeed P-flo Intake [red] // TSW Nurburgring 18x8 [gunmetal machined face]// DG Springs
  10. 11-28-2012 08:47 AM #10
    Car thief capital of canada.
    I guess a command start is the only option.
    Jul 16th, 2012
    Glendale, AZ
    2009 VW Passat 2.0T; 2007 VW Eos 2.0T;
    11-28-2012 09:06 AM #11
    Quote Originally Posted by BlazinDayz View Post
    Once you start the car with the push button start, the car doesn't stay on if you take the keyfob with you? And if it does, I would think that it would be undriveable if it does not sense the key anymore.
    I don't know how VW KESSY works... I don't have it. BUT, I did have an Nissan Altima rental for a few days, (POS btw) and it had kessy. When I left the car on and walked away with the keyfob, the MFD would say NO KEY! NO KEY! and it wouldn't be drivable but would not shut off...
    I'm curious if anyone has tried this or would be willing to try it.
  12. Member synthetikv's Avatar
    Feb 3rd, 2011
    Buffalo, NY
    2013 GLI
    11-28-2012 09:26 AM #12
    vw remains drivable it just beeps. i've driven my moms car with kessy and had her get outta the car while i parked it and it just beeps at me.
  13. Banned
    Oct 11th, 2012
    11-28-2012 10:07 AM #13
    You cant lock a VW from the outside while it is runing
  14. 11-28-2012 10:32 AM #14
    Quote Originally Posted by einsteinjs View Post
    The car remains running when you walk away from it.
    For instance this morning it was quite frosty and it would have been nice to run the car for a couple minutes allowing the defroster to work its magic while I got lunch ready. But since I cant lock it and murphy's law and all, I didnt.
