Results 1 to 5 of 5
Thread: VW Routan 2009 Check Engine Light (P1404 EGR Issue)
  1. 10-13-2012 03:58 PM #1
    My Check Engine Light came on with P1404 EGR Issue(FLow Basic Setting not carried out). I did this diagnostic at NTB, however they could not pin point the issue and recommended to go to a dealer. Did anybody have this issue before ? I am 1 month out of warranty
    Jun 27th, 2007
    58 Ragtop Bug, 2005 Passat Wagon, 2010 Routan SEL
    10-14-2012 10:18 AM #2
    Quote Originally Posted by shlehter View Post
    P1404 is an EGR valve getting hung up. I'll ask, is this on the 3.8 engine with 50-70K miles on it? If so they seem to be prone to EGR issues, a new EGR valve is pretty easy to install. Also being just 1 month out you could perhaps visit the dealer and ask for a good grace period on the warranty---ASK BEFORE they even touch your car, if not you'll be paying for the diagnostics.
    1958 VW Ragtop Bug
    2005 VW Passat Wagon
    2010 VW Routan SEL
    Be sure to check out the Original Routan Dead Pedal Click Here
  3. 10-14-2012 11:30 AM #3
    Yes, it is 3.8 engine with 15K miles on it....thanks for the info.
  4. Member
    Jun 27th, 2007
    10-14-2012 02:25 PM #4
    Wow only 15k, I'd be at the dealer and they better good grace the repair. Typically the higher mileage is when you see the egr problems. Keep us posted.
    Sent from my SGH-T989 using Tapatalk 2
    1958 VW Ragtop Bug
    2010 VW Routan SEL
  5. 10-20-2012 06:51 PM #5
    EGR Valve $80 (AutoZone)
    Installation $40
    Hope this helps...
